Question about Casio Cameras
Casio EX-Z700 was dropped in sand. When camera is turned on lens makes a grating sound and the moniter screen is cloudy. It originally said lens error, but no longer says anything.
Hello, I'm Mark Faith from the states. I purchased the CASIO EX-Z700 series.
However, I accidentally dropped the camera when the camera was on and the lens was extended.
It makes a grating sound, and the monitor screen said "Lens error".
Now, the camera is turned off with its lens extended.
When I see the lens from the top, the lens position is more concentrated to the right, and the gaps between each lens is bigger on the left hand side of the lens.
I sincerely hope this would help you to analyze the lens situation.
I'll be patiently waiting for a list of solutions.
Posted on Sep 14, 2008
How do i fix a lens error?
It's most likely that your camera has either had a knock on the lens or been dropped, if the sound is mechanical (like a whizz). If it's more clicky in nature, there might be a grain of sand or dirt stuck in it. If you have an air blower, try that on the lens. If it is mechanical, your lens will need to be replaced, either by casio or a qualified dealer. This is usually an equivalent cost to buying the camera new, unless it is covered under warranty.
Jul 24, 2010 | Casio Exilim Zoom EX-Z700 Digital Camera
Is there a way to "restart" my Casio Exilim EX-Z700? While I was taking a picture it seemed to freeze while it was trying to display the picture I just took - then, with the lens still popped out the...
Normally changing the battery solves this.Make sure you replace it with a good quality new battery and make sure it goes in the right way around as when you get in a flap it often ends up in the wrong way!
Jun 11, 2009 | Casio Exilim Zoom EX-Z700 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Casio exilim EX-Z700 lense won't open to take pictures
Hi there and thanks for coming to FixYa.
90 percent of the time, it's dirt, sand or grit that has gotten into the lens mechanism preventing it from opening properly. Try this:
Take an air compressor if you have one, or maybe you can use a friends, anyway, put the nozzle up to the camera and run it around the space between the lens and the camera to clean out any dirt or yuk that may have gotten in there. Best of luck. Leave me a comment if you have any other questions.
Feb 24, 2009 | Casio Exilim Zoom EX-Z700 Digital Camera
Lens erro, camerra wont turn on, completely dead
Casio will fix it but there would be a fee. A lens error means that there has been some kind of damage done to the lens gears. Unfortunately there is nothing that can be done by the consumer, it is something that has to be sent in. Call repairs at 800-706-2534 option 2 and tell them you have a lens error and have talked to tech support already. Otherwise they will make you call tech support. :) They will tell you where to send it.
Nov 01, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Lens Problem
Hi Kento,
Thanks for accurate description, the problem is cristal clear.
As often happens the lens had been damaged by the shock.
All you can do is trying gently to push the lens inside with your finger while turning camera on and off.
This will probably not work, as lens gears are bent and damaged.
The whole lens barrel must be taken apart and remounted. Probably some part need replacement.
If it is still under guaranty it wont be easy get this kind of repair covered, only way to cover it is if the camera came like this in package, I don't think you can get away with it.
Sep 14, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
The only way to fix a lens error is to send it into repairs. Call them at 800-706-2534 option 2 and they will tell you the closest place to send it to.
camera lens has problem.
need repair lens
mydc digital camera reapir
Jun 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio ex-z700
Your lens has sustained damage and needs to be sent in to repairs.
Jan 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Cameras Logo
116 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
