Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No audio in a hdmi connection between a macbook pro and Toshiba regza 42 " tv
  • Toshiba Master
  • 6,993 Answers
There is no audio because HDMI connection between Macbook and TV does not support sound. The HDMI you used does not have audio. In order words, you are not using the right/correct HDMI cord.
You need to connect with a single cable that carries both audio and video like the Kanex iAdapt® HDMI V2 - Mini Display Port to HDMI Adapter with Audio Support, or the Dr. Bott 9180-MDHK - Mini Display Port to HDMI Adapter II, both of which are linked below.
http://www.cablematters.com/pc-56-26-mini-displayport-male-and-toslink-audiousb-male-to-hdmi-female-adapter.aspx
http://www.kanexlive.com/products/iAdapt51.html
http://www.drbott.com/press/100415.html
So endeavor to get any of the above cord and problem should be solved.
I hope the above makes sense to you.
Good luck.
Posted on Apr 09, 2011
What is wrong with th sound on my tv. Toshiba 42"
sometimes its the hdmi cable input
to trouble shoot that switch to another type of input . like video an audio cables or channel 3/4
if it still happens then the audio circuit in tv is to blame.
Jan 04, 2015 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I connected my Mid 2009 Macbook Pro to my Sanyo DP42746 Sanyo with a minidisplay port to HDMI adaptor. My Macbook doesn't support sound through the minidisplay port. The TV owner's manual suggests...
It may have something to do with the settings under audio output devices. See if you have options, and ensure that the headphone jack (I assume that's what you're using) is set as the default sound device.
Oct 24, 2013 | Sanyo DP42746 42 in. Plasma Television
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Jan 03, 2011 | Toshiba REGZA 47HL167 TV
Toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Nov 20, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba REGZA 37AV500A LCD TV when using HDMI input picture and sound intermitantly blacks out for about 2 seconds
Does this happen with all the HDMI inputs. If only the one then jack is bad. Replace the main board. If on all HDMI inputs see if replacing the cable helps.
Nov 08, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba Regza 42" lost all hdmi input
TV was on, screen went black... Stanley cup playoffs double OT continued sound only. TV now just clicks on and off.
Mar 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
363 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
