Pool heater. auqua pro 1300. You can set temperature, then screen show's it to high to turn on.
  • 1,420 Answers
If the temperature is not too high, you will need to replace the high limit sensor.
Posted on Apr 09, 2011
I have a Master Temp 250 pool heater that shows an AGS error on the back of the board. The heater runs for about 20 seconds then shuts off, any ideas?
AGS = Auto Gas Shutoff...
What is happening is the heater is monitoring (or sorta, by reasons difficult to explain here) Water Flow and Water Temperature. In this case, the AGS is triggered by a low water flow, or high Incoming Water Temp.
High internal water temp = triggered AGS.
If you have and can confirm, PROPER water flow, water temp coming into heater is Lower than 104°, then it is possible you have a faulty AGS.
But in most cases, it's only doing its job. Locate the reason for the fault, or why the AGS Switch turned the heater off.
Jun 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
I need to know how o increase the temperature on a sunRunner 1300 pool heater
put a bypass into the plumbing and open it up about half way this will slow the water down going through the heater
Oct 01, 2014 | Pool & Spa
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My pool heater keeps showing e-05 and the heater will shut off in about 2 minutes. How can I resolve this problem myself?
The E-05 code sets when the exhaust gas temperature goes too high. This is often caused by a insufficient water flow. Ensure that you have good water flow before turning the heater on. Ensure that all valves are set to allow that to happen.
Dec 04, 2010 | Pentair Minimax NT Heater
Sta rite Maxe therm heater turns on by itself
These pool heaters have a very helpful and easy to follow chart in their users manual for problems such as this one. There are questions that you will need to answer that you cant answer unless you are looking at the heater. Below is a pdf version of the manual.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Apr 01, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
