Question about Radio Communications
My cb will turn on but i cannot talk to anyone, im getting nothing. Why?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Does it Transmit?? Does meter show transmit?? Can you hear?? If its hearing an transmit gone..it could be Microphone, or speaker, or other more serious problems inside circuit. Change mics and hook up Ext Spkr. If that does not do it, then radio is gone. Buy new radio instead of repairs.
Posted on Apr 10, 2011
  • Steve Tompkins
    Steve Tompkins Apr 20, 2011
    Its finals that make a radio not Transmit. Final is a Transistor in the rear on a heat sink.
2 Suggested Answers
  • 219 Answers
SOURCE: no talking
This could be several things, first I'd look at your antenna system,make sure its matched to your truck. When I say this you need a good ground good coax at least 18 foot,the mount and it installed right and the right kind of antenna, they make many different one because not all work on what you're installing it on. Then I'd check your mic if it has a broke wire it can also cause the problem you're having, most midland mics are wired different so don't just find another one.
Posted on May 08, 2010
Hi i have a radio shack hanheld trc-231 and a trc-241. I would like to know how i can tweak my trc231 to the max and i need to find out whats wrong with my trc241 as it has a weak transmitting signal out...
First , make an external antenna and listen.
You can make one ,
• with a use of a 9 ft long , 1 in diam aluminum tube,
• RG-58 cable and
• BNC antenna connector for your radio
Install it above the roof , 10 ft height of mask is OK
higher is better
• Use 4 guy wires as ground.
Jul 29, 2012 | Radio Communications
Well i dont really know much about this cobra 20 plus cb lol i know its old. but im trying to see if it is working well i got it hooked up to a battery and the antenna plugged in and it comes on but im not...
check the speaker it may be dry rotted and not working.use an external speaker. depending on the time of day you probably couldn't reach any one any way Get a friend to talk on another radio while you listen and then let him listen for you.
Dec 10, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a 3300hp bought it new in may it has been in the shop every month sence. iv taken it to 6 different cb shops and no one can fix it it will recive well but when i talk on it people can barely...
Hi, my name is John. Welcome to FixYa. Check your antenna, make sure it is grounded good and nothing is blocking it. Have the SWR checked. They will do it for free at Radio Shack or any CB shack. Thanks for choosing FixYa...John
Nov 23, 2010 | Connex 3300 240-Channels Base CB Radio
It doesnt work
There may not be much chatter (people talking) in your area. Try to find a local CB friend who may introduce you to the CB world.
The 2 antennas idea does not increase input or output, in fact they (without additional high powered equipment) cancel each other out. Most CBers will only connect one antenna and have another installed and not connected but only for cosmetic reasons. Its only once a very high power threshold in reached that 2 connected antennas will be a benefit. Those are the ones that there output bleeds all over other peoples TVs and AM/FM radios.
Good luck
Aduz
Mar 30, 2009 | Cobra 19 DX IV CB Radio
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Cobra 29 ltd classic side mic
First off I dont believe anyone to peek and tune but anyways. Make sure your mike is for the radio wiring. Next the guy that rigged it up might have gave you all the channels do all your knobs work??? usually you can tall as you get someone to talk with you a few blocks away and start, start turning and flipping switches till you can hear him most likely the guy that did the work on it messed it up. for a filter use a farite choke from radioshack on the mike wire.
Mar 17, 2009 | Cobra 29 LTD CB Radio
No rx
so the swr is fine antenna has not been hit by lightning i assume as the swr would be all wacke out check to see if the rf gain is turned all the way down maybe if you have little ones they play with everything as i know all so well. or mabe the squelch was turned allt the way up if either turn squelch down all the way and turn the rf gain all the way up if not the audio chip on the rt side of the board could be shoted out if the radio has pa put switch to pa with external speaker attached key mic and talk if you here yourself talking the chip is good. by the way has the radio been tweaked any time recently it may be also alignment problem??
Mar 09, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Midland model 1000
turn squelch all the way off , if you still get nothing you have a bad mic
Nov 21, 2008 | Midland Radio Communications
Cb radios
sounds like your audio chip is gone. When you say it shows carrier signal is it just showing dead key or does it show modulation when you talk? 85% chance its audio chip without having it in front of me i couldn't tell for sure.
Apr 27, 2008 | Galaxy Radios DX-33HML 40-Channels Base CB...
Losed all
The talk back may be nothing more than a 10 ohm resistor shorted across the pa/external speaker outputs. If this is the sitution, the resistor may have damaged the audio chip. Remove the resistor and see if this corrects the problem. If not you may need to replace the audio chip. Hope this helps
Ed
NC Electronic
Mills Wyomign
Jan 06, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
90 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
