Question about Toshiba NB305N410BN Netbook
My Toshiba mini NB305-N410BL suddenly won't recharge with the battery in. I have to shut down completely, remove battery, plug in AC, then re-insert battery. This is annoying. Toshiba doesn't seem to know about this. Is there a workaround? Thanks!
  • jeanette_her Apr 09, 2011
    Yes, but only if I shut the machine completely down (and remove the battery first). While I'm working on battery and it runs low, I can't plug just in the AC and get power.
    Helpful and quick advice! I just have to send this netbook back under warranty. Thanks for troubleshooting what the manufacturer couldn't!
  • 2,632 Answers
Welcome to Fixya. To be able to provide you the solution to the problem may I know if the laptop is working if the battey is unplugged and your just using the AC adapter.
Thanks
Posted on Apr 09, 2011
  • Rofel Lantican
    Rofel Lantican Apr 09, 2011
    There are 3 things to look in for this kind of problem. The Battery, The AC Adapter or the Motherboard.
    Battery Problem:
    - If you can't charge the battery but you can use the laptop without the battery and just using the AC adapter.
    Solution:
    - If you have spare battery that you can use to check if you will be able to charge it.
    Charger Problem:
    - If you cant charge the battery and can't use the laptop without the battery.
    Solution:
    - If you have a spare AC adapter or if you can borrow one just to check if you will be able to charge or use the computer without the battery.
    Motherboard Problem:
    - If you cant use the system using a new AC Adapter and a new battery or a working AC adapter and a working Battery
    Solution:
    - Motherboard Replacement
    Note: The problem requires testing the system or the components that can be the reason why you have that problem.
    If you have questions please let me know. Thanks
Won't start
the wipe out probably removed your operating system too.install a new os
Jan 05, 2012 | Toshiba NB305-N410BL 10.1 inch Mini...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Have line on the top black vertical line not so clear but its not normal
Please check if the problem can be seen in the BIOS screen. - you can go to the BIOS screen by tapping F2 repeatedly as soon as you turn on the computer.
If the vertical line can be seen in the BIOS screen, it is already a problem with the LCD screen and you need to contact the computer manufacturer for possible LCD replacement if your computer is still in warranty.
Hope it helps you.
Apr 17, 2011 | Toshiba NB305-N410BL 10.1 inch Mini...
My toshiba mini laptop NB305 will turn on but it wont boot up, and the screen stay black, how do I fix it?
pull the battery, disconnect the ac adapter and hold down the power button for about 10 seconds, then put the battery back in, plug it in and try booting it. If that works, you're good, if not then the motherboard most likely needs to be replaced.
Apr 10, 2011 | Toshiba Computers & Internet
My netbook display is blank when powered on.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Mar 21, 2011 | Toshiba NB305-N410BL 10.1 inch Mini...
How much is toshiba NB305?
Hi
Toshiba NB305 costs around $330 to $380 depending on the seller. You can check out this link for great deals---
Toshiba NB305 Notebook Deals
Daniel Scott
Jun 10, 2010 | Toshiba mini NB305N410WH Netbook
My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Open Questions:
Toshiba NB305N410BN Netbook Logo
865 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
