Question about Canon i860 InkJet Photo Printer
My printer will not print. Light is flashing yellow seven times?
This a code. Look in the manual of the printer for the meaning of this code. You also can check in the website of the printer manufacturer.
Posted on Apr 09, 2011
    Genius:
  • 1,570 Answers
Hi. What did you do before it happens?
Please try this manual resetting of the printer.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
If not try to clean the print head using a clean cloth with rubbing alcohol and then rub the print head into a plain paper with alcohol.
SOURCE: Canon i865 printer
Hi! I've got same problem. Canon userguide says that 5 flashes means the print head is not installed/not properly installed, or it is defective.Not yet sorted problem out - new print-heads are expensive!
Posted on Feb 17, 2008
SOURCE: canoni850
Go to the Canon Web site http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=8047 (may have to copy and paste into browser. I believe it is either a Print head (7 flashes) which will require repair/replacement of print head - or - a waste ink error that requires a reset. There are other posts on this site that explain how to get the printer into service mode to reset.
Posted on Oct 28, 2008
SOURCE: canon i320 amber light flashing will not print
i80 Canon printer will not print. Printer head will not cycle when turned on. First the green light came on then the amber light would flash seven times, green flash once then back to amber flashing seven times. Now the green and amber flash simaltaniously seven times. What can I do.
pangotti@verizon.net
Posted on Nov 27, 2008
jkreuzweir
  • 16 Answers
SOURCE: Canon S520 printer flashes the yellow light 8 times.
This will only slightly help...my cannon printers waste tank was never actually full, there is just a built in counter system that figures when it might be getting to that point.
To reset the count before you cant print at all because of it:
A) Turn the printer off.
B) Press and hold RESUME, then press and hold the POWER button.
C) Release the RESUME button, Next press and release the RESUME button twice more while continuing to hold the POWER button). The printer's carriage will move a around a bit.
If by some miracle we did that correctly on the first try, you are now in "Service Mode".
D) Press the RESUME button 4 times (clear waste ink counter function). The light will change color with each key press. Press the POWER button to commit the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Now for to check the waste pad...(excerpt from http://www.neilslade.com/Papers/inkjetstuff11.html)
  • Figure out how to open the printer by removing the side and inside top plastic panels. Just look at the thing and use your brain. Its all pressure clipped in place, no screws (at least on the S900 and similar models, probably still the same on this years models.) Look for slots and triangles on the 960.
  • On the i960 you'll have to remove the power buttons assembly on the front- take out the two screws, unplug the internal white electro connector plug CAREFULLY, then you can undo the last clip that holds the top in place.
  • No need to remove the ink cartridges in this process- so don't. The mechanism is held down in place in the case by two screws at the very bottom on the outside bottom of the metal chassis inside. Remove these screws then lift up the mechanism. It should lift out fairly easily, but remain attached by wires-- just place it on the top edge of the case.
  • You'll see the blackened (from waste ink) felt pads on the bottom. WEAR GLOVES-- this is skin indelible ink, the only thing that will get it off your hands is CLOROX. Period. There are two skinny pads that sit on top of a larger pad. Note how they fit together.
  • Lift the pads out and rinse out thorough in a sink until very little or no ink comes out. There's no need to use chemical or soap cleaners, just use plain water from the tap and the spray nozzle. Keep rinsing and squeezing the pads, but don't twist them like a towel, squeeze and fold in half however to really get the ink out.
  • Lay flat in the sun for a few hours to dry. Use a hairdryer to get the last bit of moisture out then replace in the printer, and put everything back together.
  • RESET the printer electronics, so you won't get the stupid "waste ink tank full" message any more. Do an online web search if this doesn't work for your model, although this works (or slight variations0 for many, including the 8200, the S800, and S900, and the i-series like the i869, i950, i960, etc.Two main buttons on the top of the printer- Power and the Resume:
If you've reset the code first, then cleaned the pad, you're now ready to print again.
Posted on Jan 04, 2009
SOURCE: My CANON iP4300 printer does not print and has a yellow light that flashes 13 times. What does that mean??
This according to the user's guide:
The remaining ink level cannot be correctly detected.
Replace the ink tank and close the Top Cover.
Printing with an ink tank that was once empty may damage the printer.
If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the RESUME/CANCEL button for at least 5 seconds, and then release it.
* With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any printer malfunction or damage caused by refilled ink tanks.
See Replacing an Ink Tank.
Posted on May 05, 2009
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
The orange light keeps flashing
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Yellow light blinks 7 times
? Seven flashes: Defective printhead
Remove and reinstall the printhead.
Also, ensure that the protective cap has been removed. If reinstalling the printhead does
not resolve the problem, replace it with a new one.
Mar 04, 2010 | Canon S900 InkJet Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Dec 27, 2008 | Canon S400 InkJet Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon i865 printer
Feb 12, 2008 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
192 people viewed this question
old marine
old marine
