Fluid levels are O.K. but it is not putting water out onto carpet and the red X on top is not spinning. Can you advise??
    Brigadier General:
  • 6,277 Answers
Although you are on the washing machine forum, I think I recognize that your machine is a Bissell carpet cleaner ;-0)
Check the belt which is situated behind the cover on the RHS looking from the front. You lever it upwards carefully. This belt is driven by the motor and drives the water pump which is also visible. Then in turn the brushes are driven. I suspect that the belt is broken.
Hope this is not too late (which it probably is as your posting was 2 days ago!) and that it is the solution (as it was with ours).
Good luck and please score this accordingly- thanks,
John C
Posted on Apr 11, 2011
Fluidmaster instructions
Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
Aug 23, 2014 | Home
Water driver floorboard carpet
On older vehicles there may be rust in the floorpan, but likely the door weatherstripping gasket has shrunk or missing a piece, allowing water entry. Also check door alignment. Misaligned door would allow water in. Also check radiator fluid level as bad heater core will allow water and coolant to wet carpet.
Jan 08, 2014 | Honda Cars & Trucks
WHEN I PUT THE MACHINE ON TO CLEAN TH CARPET THE WATER DISPENSES INTO THE CARPET AND THE BRUSHES do not SPIN and theres NO SUCTION TO REMOVE THE WATER FROM CARPET
Make sure the lower tank lid is on securely, clean the intake filter on the top right of the machine. ensure the front panel is installed (the square to remove for hoe use). this has to be in place for carpet operation
Apr 17, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Carpet wet by driver seat under floor mat
Is it water or brake fluid. Water could be a windscreen leak or leaves have got through the outside grille of the vent, blocking the drain, so when it rains the piping is full of water. As you go around corners the water leaks into the cab.
If it is brake fluid, you have a leak in the master cylinder which allows fluid to leak down the push rod, onto the pedal and into your carpet. If you are not having to top up your brake fluid it is not likely to be the problem.
Feb 19, 2010 | 1999 Chevrolet Silverado 1500
Out of balance
Installed no slip carpeting underneath machine, worked fine.
Feb 15, 2009 | Maytag Legacy Series Top Load Washer
Chevy Cavalier '98 Transmission has no dipstick - check level ?
take it to a shop and have them top it up so you can be sure you have the fluid you need to keep the car going as it should,,,,thats your safest bet
Dec 06, 2008 | 1998 Chevrolet Cavalier
No cleaning fluid or water comming out of cleaner
not sure of your model but on most of the bissell's ( except there new style) the belt drives the pump and the brush on the bottom. no pump action then no spray action. you probably need a new belt.
Sep 03, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Puts solution down will not extract
On the inside of the recovery tank lid, the foam filter, if it is all of the way up to the top of the lid, lower it to leave about a 1/4 in. gap. The red filter at the bottom is clogged. The lid is not locked onto the tank, these are the main reasons when you don't have suction.
Nov 20, 2007 | Hoover F5842-9RM Steam Vacuum
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
