Question about Daewoo KOR-63DB Microwave Oven
Heating coil is not working marking on coil is 2M218H ME 931201BN KOREA HIGH VOLTAGE MICROWAVE RADIATION PL REPLY AT hkothari522000@yahoo.com
I have a model #401-80089700. The inside wall next to the controls will get hot and the microwave will shut off. after it cools, the display comes back on and it will work until it get hot again. It
all units have a thermal fuse that stops operation when case over heats . try replacing the thermal fuse could be out of tolerance.. looking for an obstruction in the high voltage radiation ducting that could be obstructing the flow of high voltage radiation , or the defuser belt or motor is no good or slipping, also the cooling fan obstructed or failed. .. all above to be handled by a master or journey man teck. or tv repairman. A professional not an novice.
Jan 21, 2015 | In Microwave Ovens
I have a Jenn-Air JMV9169BAS microwave that doesn't heat. I looked at other similar posts and have checked the capacitor and replaced the magnetron. I can't get the diode out to check it. I don't smell any...
It's really not safe to measure the voltage while it's running unless you truly have training and experience.
The risk is not "radiation," but instead the high voltage (4000VAC) and its frequency, which can be instantly lethal.
Microwave ovens do not contain or produce ionizing radiation as found in atomic or nuclear energy. That is just a common myth.
Microwave energy is much like radio waves or light, and while it can cause burns, you'd likely pull away due to heat before much if any damage were done.
The service manual (with installation instructions) is here:
http://www.microwavecontrol.com/AMV1154_AMV5164_AMV5206_AMV6167_JMV8166_JMV8208_JMV9169_MMV1153_MMV4205_MMV5165_MMV5207_UMV1152_inst_sm.pdf
When a high-voltage rectifier diode fails, it almost always shorts, which will result in a growling / groaning sound when trying to cook, but no heat. Ideally, this test should be performed on a high-voltage diode:
9v_battery_meter_test_hv_diode-bamrfjjfhaycgefspgj211on-2-0.jpg A good parts source is the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Jenn-Air Microwave Ovens
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Code f-33
Step 1:
Symptom: Intermittent or continuous error code F33 on the display. Cause: Insufficient (poor) grounding of the controller (DP) board.Remedy: clean the groundHowever if Not Heating proceed with the next steps.
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 07, 2013 | Microwave Ovens
Can't get to heat anything can't seem to set clock first Hamilton beach model hbp90d23al any suggestions
Step 1:
see this steps and diagram and fix it. God bless you
Microwave Doesn't Heat
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Neff gmbh microwave on but not heating
Step 1:
follow this steps and test and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Step 4:
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
KOC-8H4T doesn't heat. It turns with light on but is not able to heat Pl. help
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 02, 2011 | Daewoo Microwave Ovens
GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Daewoo KOR-63DB Microwave Oven Logo
76 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
