My LG TV only show a smaller picture, may be 3/4 of the screen
  • 4,889 Answers
You have not chosen the correct aspect ratio. Please tell me whats the make and model of your tv so that I can tell you how to rectify this. Also let me know if this happens on all input sources(DVD, HD box etc.,)
Sai.
Posted on Apr 09, 2011
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
How do I eliminate split screen on an LG 47LE5400?
Chris, Is there a way to reset the TV back to factory specs?
Apr 25, 2014 | LG 47LE5400 47 in. TV
Lg 26 inch tv flat screen, no picture but sound ok!
The inverter needs replacement. You should be able to get one from www.tvrepairworld.com
Nov 03, 2012 | LG Televison & Video
The normal screen is divided in two smaller screen,which are showing the same channel.I want to return the screen to its normal screen size of single screen channel
The smaller picture is PNP called picture and picture.It can be set in to the menu setting.Go to menu setting and search the PNP code.Try to off or diable the PNP menu setting to back the normal single picture.
Jul 09, 2011 | LG 42PC3D 42 in. Plasma Television
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
LG 50PG25 Plasma TV, black screen sound still works.
this faint picture issue is usually caused by a bad z sustain board. it is the smaller scan board on the right side of the tv when viewed from the back. it has some large cables that energize the plasma panel, dont confuse with the y sustain which has the tiny ribbon cables that address each line of the picture.
there should be a # on the board indicating the part number, plug it into a search engine to find parts.
this could also be a low voltage or something else, check the Vs and Va voltages and confirm theyre correct with the ones listed on the sticker inside the tv. Be careful this is dangerous and you can get shocked if you not familliar. The heatsinks can be energized and shock you , exercise caution. if you order a z sus board, make sure you can return if it doesn't fix. I'd say 95% chance its a z sus
May 21, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Picture ratio
Programs that are recorded in 16:9 format appear full screen on a 16:9 TV. A program recorded in a standard 4:3 format will either be stretched to fit the screen or have side bars to fill the screen area. In the case of HD channels, the black side bars are part of the picture which is being broadcasted.
Apr 22, 2010 | LG 32LG30 32 in. LCD HDTV
Invalid format displays on screen
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
May 20, 2009 | LG 26LG30 26 in. LCD TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
