E1 F2 is actually "Keypad Tail Not Connected" - from the tech sheet. This usually means that the keypad has failed - unless someone recently unplugged the keypad from the control board.
These keypads are no-longer-available from the manufacturer but you can get a replacement part from
Introducing the Ledgestone Technologies Touchpad
Hello & Welcome to FixYa
F2-E1 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
