Question about IBM ThinkPad T22 2647 Notebook
Hard Drive I recently received a t22 and the hard drive was bad on it. When I get my new drive can i just plug it in and install the OS or will I have to do something special?
  • claude443 Aug 09, 2008
    My T22 2647 laptop has suddenly decided to run so slowly that it's now unusable. On switch-on it brings up XP but takes an eternity to do so. The processor is reported as running at 900 MHz, there's 250 MB memory so it looks like the hard drive needs replacing, but I can't be sure. I'd be grateful for any suggestions on next steps to take to repair it. Thanks a lot.
    Regards
    Len
Your solution is not correct! no automatic download logos...............
Posted on Aug 07, 2008
No tengo los drivres
Posted on Aug 06, 2008
    Master:
  • 397 Answers
When you boot from your OS CD it will run through Set Up and give you the option to format the harddrive.
Just select NTFS for windows 2000 or XP, or FAT32 for Windows 98/ME.
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
T22 disk read error
Sounds like the Operating System is corrupt. I would re-format the hard drive and re-install the OS that should solve the problem. If not then the Hard drive needs to be replaced.
Jan 23, 2012 | IBM ThinkPad T22 2647 Notebook
No sound device found on ibm thinkpad 2647 l
FIRST STEP:
You can download the sound drivers on this website: http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4ENRG5
This Package provides the audio driver for OS/2 users.
The Audio Features Package enables the audio function of the following ThinkPad computers:
- ThinkPad 600X
- ThinkPad T20, T21, T22
NOTES: See the Additional Information section below for instructions on what''s new in this release and how to install this driver.
This program is language independent and can be used with any language system.
c.gif c.gif File details c.gif Version: 3.10 Release Date: 2001/08/16 c.gif File link File size File description c.gif aftpitos.exe 434,478 version 3.10 - Audio driver III Diskette for OS/2
aftpitos.txt 3,011 README for version 3.10 - Audio driver III Diskette for OS/2
c.gif Additional information c.gif Click here for instructions and limitations on downloading and creating the diskette.
This Additional Information field contains the following sections:
I. Summary of changes
II. Installation instructions
III. Determining which version is installed
version 3.05
- (New) Support for ThinkPad 600X
version 3.06
- (New) Support for ThinkPad T20
- (Fix) No sound after MIDI file playback.
- (New) Support for ThinkPad T21
version 3.08
- (New) Support for ThinkPad T22
- (Fix) Hang up during Boot.
version 3.10
  1. To install device support, extract the package to a directory on the hard disk drive.
  2. Start the Multimedia Application Install program:
    • On the OS/2 desktop double click the OS/2 System folder, click the System Setup folder, click Install/Remove, then click Multimedia installation program, or
    • Alternatively, you can execute MINSTALL from an OS/2 command prompt or browse the installation diskette with the OS/2 drives utility and double-click the icon for install.cmd.
  3. Once you are in the multimedia installation program, select the drive and subdirectory you copied the driver to. The installation program will show Crystal Audio PCI (Pre-selected)
  4. Click the install button to proceed with the installation. Read and follow the instructions provided by the installation program.
  5. After you complete the installation, restart the system.
NOTE: To remove audio and MIDI drivers, select zero devices when prompted for the number of devices to install. Selectable choices are 0 and 1.
Check the following files' size.
Directory Files Version
3.06
Version
3.08
Version
3.10
C:\OS2\BOOT CWCSPUD.SYS 169181 171516 169391 CWCMMPM.SYS 45904 45900 52620
IF the FIRST step did not work then,
Contact the IBM Support hotline for assistance on Hardware configuration of the system at 800-426-7378
Feb 15, 2011 | IBM ThinkPad T22 2647 Notebook
West Digit 250 Gig drive died
This may sound crazy but this is how we recovered data off the hard drives when i was in college for CCNA.
Take the hard drive out and put it in a freezer for about 20-25min and then take it out and insert it into your laptop, It should give you enough time to recover your data. If it still will not load you could try getting a hard drive enclosure and throw the hard drive in the freezer again and make sure you have a working computer aval. and then take the hard drive out and install it in the hard drive enclosure and then plug the usb into your working computer and try and get your information off of it. Hope this helps.
Jun 24, 2010 | Western Digital WD2500BEVSRTL Scorpio...
MY PC WONT ALLOW MY EXTERNAL HARD DRIVE TO LOAD AND CANT LOCATE THE DRIVERS
If you are using Windows 98 SP2 or newer support for the external HD is built in. Installing drives shouldn't be necessary, just Plug & Play.
While it is possible the OS has become corrupted the most likely reason is a bad hard drive controller chip on the drive itself.
If very recently purchased I'd take it back to the seller and ask for an exchange. If that isn't possible, if the drive is still under warranty I'd send it back to the manufacturer for replacement. Look them up via Google and get an RMA # from their support staff first.
Feb 05, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
Aug 18, 2009 | Hitachi 0A52126 120 GB SATA Hard Drive
I have recently bought a HITACHI SIMPLE DRIVE 1.0 TB DATA STORAGE and it had no disk and no manuel and i cant seem to install. I also searched the internet and have found no software to help me...any...
if its an external hard drive then and you want to install the hard drive on your computer, you have to install the BIOS on it and then install the OS you want on it also. this will make the hard drive able to be used by your computer.
if its a portable hard drive, then just use the control panel of your computer to find the device, normally any plug-n-play device is usually recognised and installed automatically by your computer.
cheers.
cheers.
Aug 15, 2009 | Hitachi 120 GIGABYTE SATA MOBILE STORAGE...
T22
Sorry, but no function key for this. This will most likely be a hard drive failure. Start by do a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive, using a full NTFS format not the quick, and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Aug 15, 2008 | IBM ThinkPad T22 2647 Notebook
No power to hard drive Fujitsu lifebook laptop
The new hard drive will not have an OS on it until you install one, so expect a no OS found message.
The old hard dirve may have lost its master boot record or the boot cylinder is bad.
You mentioned DOS. Do you have bootable DOS diskettes available?
First plug the old drive into the desk top and copy off any data you wish to save.
Depending on the operating system on the desktop and utilities available you might be able to recreate the master boot record on the old drive. Be very careful you know which drive is which or you could cause problems with the desktop drive.
You might also be able to run DISK MANAGER and test the drive for errors.
If you can boot the DOS diskettes the command you need to run is FDISK /MBR with the old hard drive installed.
Sorry, I really need a lot more info to be more specific.
Apr 10, 2008 | Fujitsu LIFEBOOK C2210A (AKA0F0A00B001000)...
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
IBM ThinkPad T22 2647 Notebook Logo
105 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
