I have a H/P 873n computer. It has a ATI video card. It works fine however I cam getting lines threw my monter. I wiggle the card and it clears up. I tried removing the card and renstalling. Checking for dirty conntacts,etc. I wanted to enable the on board video plug on the D33007 motherboard and use that instead. I do I enable?
    Sergeant:
  • 189 Answers
- Go to "Run" and type "sysdm.cpl". - Click the "Hardware" tab. - Click "Device Manager"
- Under "Display Adapters", you should see both your graphics card and your motherboard's on board graphics. Just right-click on your on board graphics, and the click "Enable".
Hope this helps!
Posted on Apr 09, 2011
I have issues with the second ATI FirePro V7800 card. I am running Window 7 pro - 64 bit. The motherboard is ASUS Sabertooth X58. Intel Corei7. Corsair 24 GB. Both two cards were working fine...
In order to further troubleshoot this issue, I would recommend the following:
Uninstall the ATI drivers from your computer.
Shut down the computer.
Remove the ATI card from your computer, and connect your monitor to the onboard video adapter.
Turn on the computer.
Ensure the ATI software was infact removed.
Reinstall the ATI video Card
Turn On the computer
Reinstall the ATI drivers ensuring to select the proper "CrossFire" configuration
May 21, 2011 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
I am working on my sons HP Pavillion a1642x computer. I am attempting to install a Galaxy Nvidia Geforce 210 PCIe video card. The computer does not detect this card and reverts to the onboard video. The...
Well first off does the HP have the lastest bios? Does the hp enough amps on the 12v line to support the card? I do know I had a video card once that had a conflict with my bios so, if it all else fails sell the card, and buy a ati one since it seems like ati works. But first try all the above.
Sep 25, 2010 | HP Computers & Internet
It has lines and i thy another monter
when you checked with different monitor if you are getting lines that means its and issue with the video card , reinstall the video card driver should resolved the issue
www.support.acer.com you can get the drivers
Jul 05, 2010 | Acer Aspire 1710 Notebook
Choppy play with high quality video
A replacemnet video card would help some, but you still have the problem of the 440 mhz processor.
There is not a lot you can do about the processor outside of rebuilding the whole computer. If for some reason that is not an option for you, then yeah, a $20 video card from ebay might give some relief (if you know what to get.. AGP or PCI), but don't be surprised if your processor is just too taxed to render high quality video at the proper rate.
Jul 02, 2009 | ATI 3D Rage II, (2 MB) Graphic Card
I have a 915pl7ae-8s foxconn motherboard and i am trying to put a ati x1650 agp video card in it and when i start up the screen dont turn on and the board beeps two time real quick. and i have put my test...
the 2 beeps is parity error or parity curciut failure
the device is not getting pluged in right, the connector are dirty, the slots in the motherboard are dirty,
the first 64kb is the problem,
if the chips on the board can be removed than remove the chip and re install them, same on the motherboard if you have that option,
clean the leads on the video card with a #2 pencil eraser
clean the eriaser with a lint free towel or rag.
blow some air threw the card slots where you plug the cards into
Feb 22, 2009 | ATI RADEON X1650 Graphic Card
Problem with ATI Compatible FireGL 3200 Video Card
CONFLICKS WITH THE DRIVES, SOME CARD HAVE SPECAL DRIVERS FOR A CERTAIN GAME AND THEY ARE DIFFERENT THAN YOUR NORMAL DRIVERS, AND YOU WILL CONITUNIE TO HAVE THIS PROBLEM, YOU GO TO PERFORMANCE FILE OR VEDIO CARD SETTING AREA PROPERTIES ADVANCE SETTINGS
IF YOU NEED MORE HELP PLEASEW FEEL FREE TO CONTACT ME THREW THIS SITE
ROD/ CANDYMANGANDY
Jan 29, 2009 | ATI RADEON HD 2400 PRO Graphic Card
ATI Radeon 9800xl Problem. It runs fine for about a couple of minutes then the screen goes all funny. e.g. lines and green things and you can not see things clearly.
Have you checked that the card is not over-heating?
Remove the side panel of your computer and then when you can see the inside of your computer and see the card clearly, turn on the computer...
WARNING...observe only, do not at any time attempt to touch any interior hardware parts under any circumstances whilst your computer is powered on, this is dangerous and could lead to serious electrical shock if you touch any parts whilst the computer is powered up!
Observe the following: is the fan on the card working? When the screen goes 'funny' is the fan working, is it running slow etc? If the fan seems to be working perfectly fine then it is an onboard circuit problem in which case you will need to replace the ATI card or go back to using the onboard ATI.
Hope this helps.
PC Software Solutions
www.pcsoftwaresolutions.co.uk
Dec 06, 2008 | Computers & Internet
Osprey-230 video capture card distorted
you must connect all cameras to solve this problem.if your capture card supports e.g. 4 cameras and you are only 1,2 or 3 connected the image can be poore.your video card has nothing to do with this.
Aug 28, 2008 | ViewCast Osprey-230 (OSPREY230) Video...
Amilo laptop ati graphics
Test it in another computer - if the same happens then you may need to replace the card.
As regards working "on cam" do you mean that HIS screen now works properly or do you mean that others can see the image clearly on their computers. If the latter, then it still looks like a dud video card.
Have you gone into Control Panel - Display and checked the settings? I don't think that there are any settings that would create the symptoms though.
Good luck.
May 08, 2008 | ATI Mobility RADEON Graphic Card
Ati Radeon 9000 video card driver
It could be related to the display resolution settings. If you can boot into "VGA mode", that should get you started.
Dec 19, 2007 | ATI RADEON 9000 Graphic Card
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
