I have a bosch WFG 2420 washing machine. It tripped the electric switch and now it will not work. The machine switches on but it keeps on flashing on the ready light. Says in manual that the door is not shut properly, but it is?
  • 4,399 Answers
Thanks for choosing FixYa and welcome to the site. Since the code is for the door, it makes sense that the washer will not work. Try adjusting the lock switch. It may be bad but sometimes you can adjust it and mess with it. Hopefully, the washer will then work. If not, you are going to need a new one. I still don't know why they have these. They cause more problems then they are worth. If you have a questions, feel free to ask and thanks for using FixYa.
Posted on Apr 09, 2011
Changed the element in my bosch washing machine and still trips the electric ,can i wash on a cold wash without tripping the electric.
In the washing machine your hot water supply comes from your water heater. The element that is tripping is part of your electrical so no you cannot expect a different result. You will have to fix the problem first before you wash.
Feb 19, 2015 | Bosch Washing Machines
My whirlpool awo3761/s keeps tripping my electricity when water is inside the drum
I would turn off the machine and unplug from the wall. Water is conductive and if it is throwing your switch you need a professional to look at it. Ring your local washing machine mechanic. Electricity and water are just too dangerous. If you keep resetting your switch and trying to run it, just to have it reset again, you can burn out the switch in the board. My husband did that when the kettle kept tripping it. New switch in the board was about $300.00.
Feb 06, 2015 | Whirlpool Washing Machines
My washing machine trips the electric
take out the plug
remove the motor
now clean it ??
check the brushes or replace them if worn
or if you do not do this a new motor will be needed
as the motor safety switch will get blown
Feb 03, 2014 | Bosch Washing Machines
Our bosch washing machine is about 9 years old and won't drain properly. The "end" light flashes as if the drain is blocked but it's not. If we manually drain the machine we can get onto...
As you do not mention 'filter' I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 05, 2011 | Bosch Washing Machines
Bosch classic xx 5 mintues into the wash, stops and tripps elec.
Hello Sir,
I think that this is due to a faulty Main box Fuse. This usually happens when the heating elements of the washer go on. Try to inspect for faults, cracks or breakages in fuse box or in switches.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Bosch WFF 2001 has finished a wash cycle but the water will not drain or spin away, cannot open the door. There is no apparent filter trap to empty, help!
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 06, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
