Question about Dryers
I have a KEYS677EQO Kitchenaid dryer. I am getting no heat. The drum rolls, but no heat. Took the back off and cleaned all lint and dust particles. Replaced back. Plugged in, started, no heat. How do I check one of the thermostats to see if it needs replaced? Isn't there a heating unit that could be out? Thank you in advance
    Problem Solver:
  • 11 Answers
Most thermosats on dryers are set to certain tempurature. When the dryer is cold the contacts in the thermostat should be closed. Remove the wires from the theromstat. If you have access to voltmeter, use the ohm setting and put a probe from the voltmeter to each of the wire contacts on the thermostat. If the thermostat is good it should give a small numerical value. If the thermostat is bad the reading will be "0". If you dont have access to a volt meter you can make a battery tester with a 9v battery, a 6v light bulb and a couple of pieces of wire. Tape the wire to the battery, then wrap the other end of the wire to light bulb and tape it in place. To test, put one wire to one side of the thermostat and then touch the base of the light to the other. If the bulb lights the thermostat is good. Make sure the dyre is unplugged.
You might check to see if your getting a full 220v from the breaker. This would take a voltmeter. Each leg to the 220v should be 120v. You can check that where the dryer chord bolts into the back of the dryer. Put one lead to the metal frame and the other to the black or white lead, each should read 115v to 120v. Be carful to not let your hands touch the leads.
Posted on Apr 09, 2011
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
What to check when Dryer heats, but not moving air?
Does the dryer sometimes stop heating? Do you always use the lint trap when using the dryer?
May 02, 2014 | General Electric GTDP490EDWS Front Load...
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
Nov 14, 2011 | Kenmore 659 Electric Dryer
We have a KitchenAid KGHS01P gas dryer. It runs, but no heat. We took the back off, cleaned out all the lint and the "ey" and it worked. As soon as we moved it back in place, the heat is gone...
This tip i wrote covers the usual things that could be wrong with a gas dryer and how to check them.
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
I hope it helps you to fix your's and please fell free to respond (add comment) if you cant figure something out.
GENE
Sep 04, 2011 | KitchenAid KGHS01P Gas Dryer
Electric dryer spins but is not drying
Heat box may have blown the thermal overload protector or heating element / wire is burnt out.
Common problem if dust / lint has accumulated in the dryer internally. May need to dismantal dryer front and remove tumbling drum to get to heat box (unit dependant).
Vaccum clean out all the lint and dust before working on replacing or repairing heat box.
embeytas
Jul 04, 2010 | Dryers
Dryer drum is turning, heating element is heating and cycling on and off, there is no obstruction to exhaust that we can see from within the house and dryer, but clothes are not drying. model KEYS700GQ0
if it's heating and cycling try running it with the vent line off the back of dryer,also go outside and make sure the flapper is opening and nothing is blocking it,when was the last time you cleaned the dryer?you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and if you have a long vent line from the back of dryer to outside vent i use a leaf blower to clean out the line,also if you have a shop vac blow off the motor and you can blow all the lint from the back of the inside of dryer to the front so you don't have to remove the drum
Apr 10, 2010 | KitchenAid KEYS700LQ Electric Dryer
My matag dryer is about 7 yraets old and it seems to be taking longer to dry? could this possibly be a heating element?
Not so much the heating element but the seal of othe drum to the door side and the back side need to be replace after long usage it get worn out and heat leak from the drum ...out
also make sure the duct from the unit to outside the house is clean from lint and dust...
Jan 03, 2010 | Dryers
Dryers Logo
98 people viewed this question
Top Dryers Experts
