Question about Ovens
The old element on my Neff B1920 single fan oven has 3 connectors. the new element has 2 . What can I do?
murdozzz2
  • 75 Answers
SOURCE: neff fan oven heater element
hi there the solution is simple neff have done away with the earth connection on the element it's now earthed through the screws which hold it in place to the cavity just tape the earth with insulating tape and secure out of the way of the fan, hope this is of some help
Posted on Apr 04, 2008
  • 3 Answers
SOURCE: Neff fan element
All of this can be done with the oven in situ. Take the back off if you like, but its un-necessary, dirty and time consuming. So here we go: Power off at mains. Remove 4 screws holding plate which guards the fan. You will be faced with the fan partially obscuring the top element retaining screw. At the centre of the fan spindle is a reverse threaded nut. WD40 the nut. Wait a minute or so and using a socket wrench and a flick of the wrist, the reverse thread nut should losen v easily. Having mastered the lock nut, tap the washer and it should become loose enough to remove by hand. If not, it just needs a little gentle persuasion with a flat head screwdriver where it sits on the fan itself. The grime will loosen and it will pop off. Squirt some WD40 onto the fan spindle, and wait a couple of minutes. Ignore any advice to lock onto the threaded spindle because if you damage it, your relatively cheap repair will become pretty expensive. Simply use a locking mole grip on the fan itself where the locking nut sits against it and pull and twist gently away from the spindle. You will be surprised how easy this is. Very little chance of damage. You can then access all 5 element retaining screws. Gently lever out the left foot of the element from the oven housing. Remove the spade connectors from the old element. Reversal of these instructions to fit the new element. Restore mains power. Reset clock or main oven will not work.
image_icon_name.gifSi Boon
image_icon_date.gifSeptember 2008
Posted on Sep 23, 2008
  • 228 Answers
SOURCE: Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Posted on Jul 20, 2009
apart4u
  • 213 Answers
SOURCE: replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
Testimonial: "thank you very much very helpful"
arepairman
  • 20 Answers
SOURCE: MY NEFF DOUBLE OVEN IS ABOUT 8 YEARS OLD I HAVE
it sounds to me that the fan is not working properly. as the oven gets older the fans become weaker and then doesn't blow air over the element at a rate that can the temp down enough..
regards
Richard Saupe
http://www.saupe.co.uk
Oven Specialist
Posted on Mar 14, 2010
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Replace fan motor in an electric fan oven
Jan 13, 2010 | Neff B1421 Electric Single Oven
Tip
Common heating faults with Neff B1476 single oven
on Jan 19, 2010 | Neff B1476 Pyrolytic Stainless Steel...
Tip
Common heating faults with Neff B1691 single oven
on Jan 19, 2010 | Neff B1691 Single circotherm super...
Tip
Common heating faults with Neff B1451 single oven
on Jan 19, 2010 | Neff B1451 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1432 single oven
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1428 single oven
on Jan 19, 2010 | Neff B1428 Nostalgic Single circotherm...
Tip
Common heating faults with Neff B1641 Single electric oven
on Jan 19, 2010 | Neff B1641 Single circotherm super...
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
