Question about Kitchen Ranges
My Aunt gave me a Hoover Steam Vac Silver, Moden # F5858-920. She also gave me the cleaning supplies to go with it. She had just lost the instruction manual! So now I have this machine with no idea how to BEGIN to use it, but need to clean my carpet very badly. Don't want to hire someone when I have this perfectly good machine to use. Is there a way to get an instruction manual for this machine?
  • Kitchen Ranges Master
  • 2,131 Answers
Maybe this manual is close enough:
Hoover F5858910 Owner Manual
Posted on Aug 08, 2017
  • 3,498 Answers
  • 1073 Answers
SOURCE: Manufacturer's Instruction Manual to Use Self cleaning feature for Gas Range
go to www.vikingrange.com/media and type in the model and you can dounload it from thier site
Posted on Apr 23, 2008
Agent Don
  • 310 Answers
SOURCE: hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Hoover steam vac spin scrub
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
micromaster
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
huuum
  • 750 Answers
SOURCE: Maytag Gemini Ga Stove/Oven 30"
Hello Steve
Welcome
You said , We lost the instruction manual...can someone show me how to turn on the self-cleaning function on both the upper and lower ovens? Thanks, Steve O.
The instructions are to long to put in here and will not fit.
so here is what you asked for at the original site.
Whirlpool owns Maytag now so your manual is at this site and the cleaning page starts on page 12.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
Thank you for using Fixya,
Huuum
Please remember to leave a solved rating!
Posted on Oct 17, 2008
SOURCE: My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Posted on May 27, 2009
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bare floor attachment for Hoover steam vac with surge clean
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
Oct 28, 2008 | Hoover F5906-900 Upright Steam Vacuum
Need manual for Hoover steam vac. F5910-900
For an appliance or any kind of electronic,
I would try http://userguides.50webs.com/
Aug 20, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Kitchen Ranges Logo
854 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
