Question about Hayward Aquabug Above Ground Pool Cleaner Hay500
My lady bug will not move when inserted into the water. There are no hose kinks or anything. Any suggestion
  • 640 Answers
Check, first, to make sure that you are getting proper flow through your pool cleaners lines. Make sure your leaf canister, hair and lint pot, and filter system are clear of debris and have a free flow of water. You will also want to check for a blockage in the throat of the cleaner. Worn shoes and wings will also cause little or no movement so replace them if they are showing signs of wear.
Posted on Apr 12, 2011
I have a Miele g7856 and I just replaced the drain hose now I get a F2E code ?
The F 2E code indicates insufficient water coming into the dishwasher. Thus you should check that the shut-off valves for the incoming water lines are open. Make sure that the incoming water pressure hasn't decreased and that the water lines aren't kinked or blocked. You should also check the water inlet filters (at the screw connection of the hose) and the flow restrictor insert in the waterproof system.
Since the dishwasher was working before the drain hose was replaced, closed shut-off valves and kinked hoses are particularly likely. You may also want to replace the inlet hoses themselves. (Some anti-burst hoses will restrict the water flow if they detect a leak.)
I hope this helps.
Oct 19, 2016 | Miele Dishwashers
Why does my machine make a loud humming noise after filling with water ?
It could be that one of the fill valves is stuck, or the fill hose is kinked, or that the water supply to the cold fill hose is blocked. If you have access, check that the external cold water isolating tap is ON and the supply to it, then confirm that the hose is not kinked. If your machine has been moved recently, perhaps for cleaning or decorating purposes, a kinked hose is the most likely cause.
Jan 09, 2018 | Washing Machines
How to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
Dishwasher won't drain
Good Morning Jean,
I see that you are having trouble with your Frigidaire dishwasher, model# FFBD2411NS, draining. There are a few things I would suggest:
1) If the appliance is hooked up to a food waste disposer, make
sure the disposer is empty.
2) Check to see if the knockout plug has been removed
from inside the food waste disposer inlet.
3) Check to see if drain hose is kinked.
4) Check the glass trap filter to see if anything is preventing the water from draining.
5) Overfill Protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean occasionally with
household cleaner containing vinegar or bleach to dissolve any buildup.
If none of these suggestions help your dishwasher to drain the water, I suggest contacting your local authorized technician.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire FFBD2411NS
The washer is not draining enough to stop smelly odor. How do I fix it?
Did you check the drain hose for kinks? Can you actually see water in the tub after a load?. Some ladies like to use too much detergent, gradually causing a build-up of undesolved detergent.
May 11, 2011 | Whirlpool Washing Machines
I have a 2001 hyundai accent, when i pump fuel, it is only taking about fifty cents at a time.
I would suggest the fuel tank breather is blocked,sometimes bugs can build their nests in there blocking the hose,or maybe the vehicle has had an accident in the rear recently and the hose is kinked.
May 17, 2009 | 2001 Hyundai Accent
Not making ice
The kink in the hose should not have caused anything to burn out. There are no pumps in the fridge - normal water pressure is sufficient.
There's a pair of solenoid valves in the back - one for the icemaker and one for the water dispenser. They operate independently but are usually built into a single assembly. If the electro-magnetic coil is burned open on one or both of them, then you need to replace the valve assembly.
Another possibility is frozen water in the line.
Oct 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Hoover Premier 706 (model A6950) washing machine.When filling water wont shut off.Turn power off water shuts off.If I remove hose from side of bowl and gently blow into it water shuts off.Machine is old...
Inserted flexible piece of thin wire into hose connectioin on outside of bowl and vigoursly wriggled it around - replaced hose and bingo water fills and shuts off and machine operates correctly. Seems like the hose connection was blocked, not a very scientific repair method but seems to have worked. Thanks.
Aug 14, 2008 | Hoover Washing Machines
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
"Dr" error code
Your pump is either bound up with something in the chamber, or there is something in your discharge hose blocking the water from escaping.
Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Check if there is anything in the chamber that is binding the impeller. If not, remove the metal back and check that all three of the hose connections to your pump are open and have no debris/ change, etc. If there is nothing binding your pump in any of those locations, your pump motor may be failing. I would suggest calling someone out to assist you.
May 05, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Hayward Aquabug Above Ground Pool Cleaner Hay500 Logo
993 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
