Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
How to remove back panel safely so i can clean dust out of projection area
  • 4,889 Answers
The best way to go about this would be if I send you the service manual which has detailed disassembly instructions with pictures. Please let me know whats your ID so that I can send it to you.
Sai.
Posted on Apr 09, 2011
How to clean the project television. There is a shadow
Hello
To clean the lens and mirrors of your projection tv follow up please.
Unplug the TV from the power supply. Never undertake any type of repairs on electric equipment without first disconnecting from power. Take care in handling any electric parts, as some may contain a residual charge that can shock you.
Remove screws from the back cover and connection area of the TV. Be sure to put them in a safe place, or on a piece of paper with notations for where each one fits in the television
Gently remove the back cover. Locate the mirror and three projection "guns," as these are what you want to clean eventually
Use a camera lens cleaning cloth (or other very soft and gentle cloth) to clean the mirror and lens. Gently remove any other dust before closing the TV.
Replace the back cover and screws. Plug back in the power supply
Turn on the television. Check to see that everything works correctly and that your picture is now clearer
Mar 22, 2011 | Hitachi 43FDX01B TV
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Cleaning mirror and how to get in there
Hello timbick45,
You want to remove the top rear panel. Remove the screws and the top, along the sides, and along the middle of your TV (from the rear). Onec that is done be very careful because the mirroe is attached to the rear panel of the TV. set the back down and with a clean cloth and a can of air remove the dust off of the mirror, use a light window cleaner, after removing the dust. To clean the bulbs just use air to blow the dust off (not not attempt to clean the bulbs with any solvent.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technology-llc.com
Mar 30, 2009 | Toshiba 50H82 50" Rear Projection...
Mitsubishi WD-62527 replacement lamp install and brightness low
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Dec 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Screen is dim and not very bright
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Dec 09, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Dust inside the screen
You have to disassembly the unit. Most of the screws that need to be removed are on the back of the unit around the face's edges. But there are a few inside that need to be taken off, and the front bottom needs to be removed.
Nov 19, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Air fitler cleaning
REMOVE THE BOTTOM PANEL OF THE BACK OF THE TV. CLEAN OUT PANEL WITH WATER AND DRY.(IF NOT DRYED OUT PROPERLY CAN CAUSE SHORT) CLEAN OF THE FAN ON THE BACK RIGHT SIDE (REMOVE ALL DUST) THEN REINSTALL BACK PANEL. TV SHOULD WORK
Nov 07, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Epson livingstation 45" tv
I just fixed the problem on my epson 57" living station. The picture is like new. Yo have to clean the dust off of the the 3 lcd lenses. (I'm not sure if thay are actually called lenses)
You can get to these by entering thru the front of the TV. Yes the front. You must remove the screen. There are A LOT of screws. This screen housing covers the entire front of the tv. and you have to remove the back panel and ALL the screws on the back of the tv to get it off. The only electronics that have to be disconnected are the Speakers and the front control panel. They both have snap connectors. After you remove the entire front panel which houses the screen and expose the inside mirror you will see more screws. You must remove those as well to remove the mirror housing. DO NOT REMOVE THE MIRROR FROM THE HOUSING. Note that there is a peg that is next to a screw in thre front of the mirror housing thst you must pull the plastic housing out in that area to release it.After you remove the mirror housing you will see the 3 LCD panels or lenses. YOU DO NOT HAVE TO REMOVE ANY ELECTRONICS OR SCREWS AT THIS POINT. Use a can of compessed air to spray the dust out of this area. I used a vacume to catch the dust as it flew out in the air. Try to hold the can as upright as possible.Keep hitting it with the air until no more dust comes out. Put the tv back together. As you open up the tv you will see dust everywhere. I took the oppurtunity to clean as much as I could. The Mirror though was clean an I was afraid to touch it.
I am a Construction Salesman yet fairly handy. I have no electricle experience. This took me 2 1/2 hrs. I spent the first 45 min. trying to get to the lcd panels from the back of the tv. Don't waste your time. You can't.
Mar 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Sider webs
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Sep 01, 2006 | GE 46GW947 46" Rear Projection Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
