Furnace is cold. Will not ignite no matter what the thermostat is set at.
  • 1 more comment
  • Chandler Ede
    Chandler Ede Apr 09, 2011
    Tell us what make and model number the furnace is and we can help you
  • Rich Landrum Apr 09, 2011
    It would help to know what type furnace you have (Manufacturer, Model number and fuel type) to be able to help you.
  • Chandler Ede
    OK, tell us the make and model number of the furnace and we can help you!
    President:
  • 1,515 Answers
You may have a faulty stat. It could be several things, but this is the 1st place to start. Remove the front section of the stat to get to the wires. You will see a red, green, white, yellow, and if its a heat-pump more. You say furnace, so I'm sure its gas fired and not a heat-pump. Take a piece of jumper wire, insulated and hold one end to the red connection and the other to the white which is heat. It may spark on you, but don't be alarmed as it is a very mild 24 volts and will not harm you. Have someone listen to see if it starts to ignite. If it does and comes on, your stat is faulty. This is a very simple test we always do 1st. If it does not make any difference, check for power going to the stat. Take the red wire coming in and touch it to the w, or g terminal to see if it sparks or the fan comes on. If not, you have lost power in the furnace unit. See if you have a small control fuse in a circuit board that may have blown, this depends on the age of this unit. It looks like a auto fuse, 3 to 5 amps.If the fuse is good, make sure you have high voltage to the unit. You may have a breaker tripped. Please keep me posted. Thank you,
Shastalaker7
A/C, & Heating Contractor
Posted on Apr 10, 2011
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Help! I'm cold. Thermostat went blank. Going to
just determine what kind of system you have and make sure the new stat will work. (did u try batteries in the old stat? Is the power on to the furnace?
Sep 30, 2009 | Honeywell Programmable Thermostat Heater
Dellllllllllluxe programmable thermostat chronotherm plus iv
Does your thermostat have batteries. What is the brand of furnace and model # . Does the furnace have a pilot light or is it electronic ignition. if you need heat you can take thermostat of wall and take wires that are labeled r and w and wire nut them together to see if furnace comes on. Make sure you turn breaker off to furnace first before you take thermostat off the wall. If furnace comes on after you turn power back on after you connect those two wires together then you will probally need new thermostat. If not you have a problem with your furnace. If you have any questions after you try this feel free to ask any more questions.
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
