Question about KitchenAid Kitchen Ranges
Glass cooktop hole half dollar size round sixteenth in.deep ?
  • 10,865 Answers
Hello don... there is no repair kit for this problem but there are many remedies that various folks have tried. Here is a link to many of those options which you can read over and then decide upon.
http://www.diyforums.net/repair-chipped-glass-cooktop-4329220.html
Joe
Thanks for choosing Fixya!
Posted on Apr 09, 2011
Smeg hob cracked on the bottom left side. It still works perfectly, however I'm wondering if I can just replace the glass, or if I need to replace the whole thing? Im looking for the cheapest option
The cheapest option is to araldite the crack (assuming it's not over the hot part!) and live with it. I doubt it is economically viable to replace the glass, it will be quicker and easier to replace the hob if you can get one with the same hole size. The only way it would be cheaper is if you find a second hand one on an auction site. You might be covered on your buildings insurance but a claim won't be cost free.
May 12, 2014 | Smeg 23 in. SA435X Electric Cooktop
Simpson fabulous 400 oven
best to measure the the hole size and then go and see a glazier for him to cut you a new heat treated piece.
Jan 18, 2014 | Jenn-Air Cooktops
I have a hole in my ceramic thermador induction cooktop
You really can't. Ceramic can be repaired but it can be short term. There may be a sealer they can put in the opening.
Jan 02, 2013 | Thermador 36 In. Silver Induction Cooktop...
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Apr 23, 2010 | GE 30 in. Profile JGP932 Gas Cooktop
MY FRIGIDAIRE CERAMIC COOKTOP IS CRACKED, CAN I REPAIR IT?
yes u can,, most have 5yr parts warrantys though i would check your manual or get ur purchase date,, DO NOT tell them u broke it as it doesnt relate to consumer accidents.. just say u were cooking and heard it shatter if its under warranty.....most glass cooktops can vary anywhere form 200-400 dollars ive seen some geprofile cooktoops glass tops up to 900 dollars just for the glass.......... It is possible to replace most are expensive and most are backordered parts occasionally manufactures might stock the item it just relates to your particualr model number.... you can do this also but will have to transfer elements over to new glass,, u may want service one this *** all wiring and elements must be mounted exactly the same as removed .. hope this helps
Feb 05, 2010 | Frigidaire FEF366 Electric Kitchen Range
Cooktop igniter sparks but gas will not light
hello there. i can help you.
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician
Jun 04, 2009 | Jenn-Air JGC8536 Gas Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Deep scractches on glass stove top
hi there,
you can try and use a cleaner intended for glass cooktops. if the scratches are deeper than that, i would recommend replacing the cooktop itself, as the heat from the elements may cause it to crack.
thanks
Sep 30, 2008 | Kitchen Ranges
Kitchen Ranges Logo
267 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
