Question about Watches
Just purchased a ridgeway grandfather clock sn#89003408. :There was not an owners manual with it. Need info on setting up clock and adjustments. Can you set it by just moving the hands (minute hand)?
SOURCE: Setting the hands on this watch
press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
Now hold the "forward" button and the minute hand is moving.
Enjoy :o))))
Posted on Feb 03, 2008
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
escapement
  • 2334 Answers
SOURCE: how to set the hands to adjust time
Find manual for your Casio in my tips and tricks.
Posted on Jan 23, 2010
  • 2501 Answers
SOURCE: chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
Posted on Feb 01, 2010
  • 2501 Answers
SOURCE: Watch hands don't coincide with the digital time.
This usually occurs when the battery is changed. There should be a process for synchronising the two times detailed in the manual.
To get a manual you go to "http://tissot.ch/" and on the black menu bar at the bottom of the page you will see "product support". Click on this and you will go to a page of instructions. Download yours and find the relevant method for putting your watch right.
Posted on Apr 30, 2010
Testimonial: "You were right. I downloaded the manual and the synchronisation instructions were there. Still not sure how it happened. But thanks so much!"
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased a Howard Miller grandfather clock and its keeping time but the pendulum is barely moving. What vould be the problem?
If the clock has a real clockspring mechanism ( with dozens of visible gears), then the problem is likely it needs to be cleaned.and adjusted.
I have a Ridgeway Grandfather clock ser # 95016098 what is the age and approximate value
from what i can tell, it's a model that is no longer made but was produced from 1984-1991 and depending on production number (the last four of the serial, the first four being the model) they are selling online anywhere between $500-$3000 i would contact http://www.ridgewayclocks.com/ and see if they can give you more detailed information. hope this helps
May 09, 2016 | Watches
Polaris grandfather clock runs slow need to adjust time up
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Nov 17, 2012 | Watches
G.E. Grandfather clock The Adams
I assume you have looked on the Internet to find the manual. Even with all the trillions of things you can find, probably no one has uploaded that manual yet. I had a clock shop for over 30 years. Most grandfather calendar dials can be set by using a NEW pencil eraser. Try to use it near the center of the dial, not on the outside edge. Move the dial clockwise. I suggest a new pencil eraser because a used one can leave smudges on the dial.
Oct 30, 2017 | Watches
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Watches Logo
245 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
