Question about Belkin Wireless Surf Router (F7D2301)
Belkin SurfN300 router's red light comes on (solid) and recognizes a connection, yet internet connectivity reads "limited access" with yellow triangle and exclamation mark. Worked fine before, then one day it stopped working. Can only get internet access through modem only
SOURCE: Belkin Router problem
A red light on your belkin router means its already busted as you decribe other lights are not ON at all. In all other types of modems and routers Red LED light on it mean synching up and if more than 20 secs with a red light is already considered busted.
Note: You may also check your phone cable rj11 , power surges, defective phone jack.
Posted on Jun 15, 2008
Neoklassic1
  • 70 Answers
SOURCE: Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Posted on Oct 14, 2008
  • 67 Answers
SOURCE: Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Posted on Mar 28, 2009
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
Posted on Sep 23, 2009
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
Why i can connecto to internet with a solid amber light?
Start -> Run ->Type in services.msc ->Click the OK button ->Scroll down to Wireless Zero Configuration and select it.->Action -> Properties ->change the Startup Type from Manual to Automatic.
Apr 27, 2012 | Belkin Computers & Internet
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
I am using Belkin F5D7234 router.I can access the Wifi from my laptop very well but sometimes the internet connection is lost i.e in 1-2 minutes, the it automatically got connected and disconnects again...
While facing the problem, check the lights. Is it changing or not?
If it changes, The problem maybe with the router. Contact Belkin: 18002235546
If it is not changing, You need to contact the ISP.
Feb 21, 2011 | Belkin F5D7234-4 Router
I have Belkin F5D7234-4-H V5 Router and I have one computer connected by cable and laptop connected by wireless. Computer on cable have constantly connection to the internet, but time to time laptop losing...
Go to http://setuprouter.com/router/belkin/f5d7234-4v5/login.htm and then follow the instructions following: Login to the Belkin F5D7234-4v5 Router and work your way down through the instructions.
Jun 12, 2017 | Belkin F5D7234-4 Router
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Jun 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Surf Router (F7D2301) Logo
332 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
