Question about Canon PIXMA MP830 All-In-One InkJet Printer
Black ink stripe down center of back of page - Canon PIXMA MP830 All-In-One InkJet Printer
3 Suggested Answers
issy2
  • 460 Answers
SOURCE: Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Posted on Mar 20, 2008
SOURCE: MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Posted on Jul 19, 2009
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Black stripe down back of page, replaced all ink tanks but still have problem - is it the printhead?
Not the printhead, it is waste ink coming up under the exit rollers. You need the printer cleaned and a mylar shield installed under the printer to keep it from happening again. In our shop it would be just a labor charge of $69.00 to repair.
Jan 06, 2010 | Canon PIXMA MP830 All-In-One InkJet...
When printing on my Canon PixMA iP4500 printer I get a 3/16'' black stripe down the back of the page which ruins the page and uses excessive ink.
Thank-you for clarification.
Because the line or marks are on the back of the paper I suspect that it may be a faulty ink cartridge. Your first step would be to press te paper feed button on the printer; it should send a clean page through. If the markings are there then you must inspect the printer for any hidden pools of ink. clean all the areas with methyl hydrate, including rollers. Replace the black cartridge with a new one. I suspect that your current cartridge is one that you have had refilled. A refill is very economical but sometimes they damage the fill port seal allowing air pressure to push the ink out causing a pool of ink. Because the ark is allways at the RHS, were the printer jet assembly parks itself I suspectyou will find the pool of ink at that side. It would eventually drip itself dry. Buy a new cartidge.
Dec 01, 2009 | Computers & Internet
Faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Apr 04, 2009 | Samsung CLP 300 Laser Printer
When making a copy we get an ink stripe down the center
open up the document feeder and clean the scanner glass.
Jan 21, 2009 | HP 1040 Plain Paper Inkjet Fax
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830
You most likely have some ink residue on the pickup, feed, or registration rollers for the problem to be on the back of the page. Use a flashlight and a q-tip moistened with isopropyl alcohol to swab all of the rollers in the paper path and see where the higest concentration is. You could also try to LIGHTLY dampen a sheet of paper with alcohol and print a "Blank" page a few times with it then do the same with fresh paper.
Jun 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
22 people viewed this question
old marine
old marine
