Question about Whirlpool WMH1162XVS Microwave Oven
Doesn't heat anything up any more. Everything else works. Sounds normal when operating. Probably a key part replacement, is it a DIY job or do I need to pay someone?
    President:
  • 2,992 Answers
If it was just a simple matter of popping in a replacement part, you could probably do it yourself. The trouble is that you need to figure out what part is bad, or what other problem is causing the oven not to work. (It's not always bad parts; sometimes it's a connection that's come loose or an interlock switch that's out of adjustment).That means working on the oven with power on and the cover removed, which exposes lethal voltages. It also means being able to follow the circuit diagram and knowing how to measure voltages and test components. Unless you have the tools and skills to do this, you should pay a professional to check the oven and give you an estimate for the repair. This will keep you safe, and will ensure that repairs are done correctly to avoid possible microwave leakage or other improper operation.
Posted on Apr 09, 2011
XL1800 buzzes but heats
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor too. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
May 11, 2013 | GE XL1800 1100 Watts Microwave Oven
Was working then everything went dead
If after a reset, at the household circuit breaker box, does not prove to be successful, sounds like you will need a new control board and a full diagnosis to make sure the board did not short anything else out internally. This is not a typical DIY job, so I would recommend a technician complete this for you.
Dec 24, 2012 | Frigidaire FMV145K Microwave Oven
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Will not heat, you can hear all the sounds like it is working
Your probably hearing just the fan. If the primary part, (the magnatron), is bad you'll get no heating. With the cost of microwaves dropping dramatically you may be better off buying a new one, rather than replaceing the magnatron.
BTW, replacing the magnatron is not a DIY job.
Nov 10, 2010 | Hotpoint Microwave Ovens
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Everything seems to be working but it doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 11, 2009 | Sharp R-530ES Microwave Oven
Microwave doesn't heat anything
Benjamin
Apr 19, 2009 | Frigidaire GLMV169D Microwave Oven
I have a hinari lifestyle microwave 800w,it has power but no heat
no it sounds like the magnatron throw away job :( hope this helps regards jim
Apr 03, 2009 | Microwave Ovens
Whirlpool WMH1162XVS Microwave Oven Logo
152 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
