Hi my medion md9494ak moniters screen wont show anything but the power light is on can i do anything to fix this? thanks tony
    Sergeant:
    Champion:
  • 207 Answers
You have a damaged board or a loose wire, nothing come's on.
Posted on Apr 09, 2011
Accer asspire 5535 screen wont lite up but works with external moniter
so you had a new inverter put in, are you talking about the actual backlight? can you see anything on the screen at all? point a flashlight at the screen when it's turn on and try and look from different angles to see if you can see anything on the screen. you can also take the screen off and check the connection to the actual LCD.
Jan 27, 2012 | Acer Aspire 5535-5050 Notebook
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
My medion akoya MD 96970 laptop screen displays multiple screens that tile down the page. its shows about 8 screens that have lines running through them. i have tried system restore and a disk error scan,...
well, i have to upset you. if your medion laptop shows you six screens instead of one and each one of them is somehow not clear enough it means your graphic processor is down, if your laptop is still on warranty send it to get your mainboard replaced with a new one, with an newer graphic processor installed. I acctually work as an service engineer for medion and in this model it is a common problem, every gpu is broken from the beginning and it is only a matter of time until it will burn. If you are thinking abt buing another medion laptop, think twice or buy those newer ones like p761x, s561x or so..
Mar 03, 2010 | Computers & Internet
Moniter doesnt show anything
ok check you video driver because if your moniter is working with other computers then that could be what it is but let me know if anything else happens
Nov 07, 2008 | Soyo SY-K7VME Motherboard
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Medion 2080 notebook battery wont charge
Time for a new battery. If you have a batteries plus in your area or order online.
Aug 13, 2008 | Medion MD-40954 Notebook
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
