Question about Sony Handycam CCD-TRV68 Camcorder
Exposure wheel does not seem to have the proper range.
Everything works great except the exposure wheel. When you push the exposure button the bar comes up on the screen and the pointer goes side to side as you turn the wheel. Only the right 1/3 of the bar seems to have any effect on the picture brightness and as a result the brightness cannot be turned down enough to shoot outside when it's sunny. You get a washed out picture even with the pointer set to the far left. Works fine inside or when it's cloudy outside. Any thoughts?
  • 169 Answers
The scroll button is already losing contact that why is not working properly..use a lighter fluid to the button then roll up and down untill the button is clean don't put to much fluid ok...
Posted on Aug 07, 2008
My Nikon Coolpix S01 takes a very faded picture, which also shows on the screen. What caused this, and is it fixable?
All I can think of is either white balance, or exposure compensation. Have either of these deviated from the norm ?
Oct 06, 2016 | Nikon Inc Nikon Coolpix S01 Silver
How do I change the aperture when my camera is in manual mode
You have to hold down the exposure compensation button at the same time as turning the control dial.
The values appear on the control panel screen.
I found this on page 33 of the manual...
Set the mode dial to M and turn the control dial to set the value.
• To set the shutter speed: Turn the control dial.
To set the aperture value:Turn the control dial while holding down the
[+-](exposure compensation) button.
The exposure level indicator appears on the control panel screen, showing the difference (ranging from -3 EV to +3 EV) between the exposure value calculated by the currently selected aperture
and shutter speed compared to the exposure value considered optimum by the camera.
Oct 13, 2014 | Olympus EVOLT E-410 Digital Camera
The built in speedlight on my D 70S is not synching. Seems like the flash goes off before the shutter opens.My pictues all comes out dark no matter what I try. Can you help me?
I fixed this same problem with my D70s today, after twelve months of getting dark pictures despite the flash firing. It started syncing properly after I performed the following, though I'm not sure why as I was just mucking around.
- Set Program to P. - Push button to activate built-in flash. - Push, and keep depressed same button, which will put you in Flash Exposure Compensation mode. - My Flash Exposure Compensation was on +0.3 so I set it to 0.0 by turning the front wheel. Seemed to fix it.
Sep 23, 2009 | Nikon D70s Digital Camera
Sony TRV308 Camcorder is not picking up light when recording
Hi there and welcome to FixYa.
Do your videos come out dark when you play them back? Or Is it dark while you are recording?
If it's dark while you are recording, is it dark in the viewfinder, or the LCD screen?
If your videos come out dark when you play them back, check the manual exposure. Hit the exposure button and turn the sel/push execute wheel to change the exposure to lighter.
If you are looking through the view finder to record and it's dark, check to make sure the window is clean.
If your LCD screen looks dark while your recording, put the power switch to player, hit the menu button and scroll down to LCD, select it and turn the select wheel to brighter.
I had to guess at what your problem was due to the information you provided, so I tried to cover the most obvious. If I failed to answer your question, please comment and be more specific.
Hope this helps, and thank you for coming to FixYa.
Rob
Mar 20, 2009 | Sony Video Cameras
D70s problem
Check the exposure compensation setting to ensure it's set for +/-0. To do this, set the camera for Program mode. Locate the exposure compensation mode button - it's the button with a +/- on it immediately behind the on/off switch. With the camera on, hold down this button. If it shows anything other than "0", use the main command dial (the wheel on the back) to change to setting to 0.
The reason the camera works in the Auto mode is because the exposure compensation settings are not available in auto mode, but are available in Program (P), Aperature (A) and Shutter (S) modes.
Sep 30, 2008 | Nikon D70s Digital Camera
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Over-exposure with AF Nikkor 70-300 telephoto
Friends have you tried not using the A-Aperture mode?? Set in on P-for Program or M-for Manual, this should produce the colors you are hoping for. If your photo is still "hot" use the + or - button called the Exposure compensation button on the top of the camera, push that little button and turn the outside main control dial where your right thumb sits 1 third stop at a time, (you have 4 to 5) The + adds light to your photo and the - will make your photos darker play with that and let me know. Barry Brown www.coralreefphotos.com
Jun 26, 2008 | Nikon D70s Digital Camera
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
Exposure compensation problems
The exposure compensation stays where you leave it unless you do a full reset or a custom reset, and except when you're using scene modes. But you don't need to do a reset to cancel out an exposure compensation -- simply use the exposure compensation button to adjust the compensation back to 0.0EV.
Nov 12, 2007 | Olympus EVOLT E-500 Digital Camera
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Sony Handycam CCD-TRV68 Camcorder Logo
147 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
