Question about Samsung B2030 LCD Monitor
Auto adjustment and some other control keys are locked
  • 11,361 Answers
Http://www.fixya.com/support/r4616564-samsung_lcd_monitors_lock_unlock
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 10, 2011
Why does the steering wheel on my 1999 Lincoln Town Car lock up? sometimes can't start the car the key won't turn and the steering wheel won't turn seems to be locked.. if I keep trying to move the...
Tiberg,
sounds like needs some oil down in to lock its getting dry i had this u will find it works 3 in 1 oil will do also push key in and turn it on an of to loosen up lock a few times, trans is it auto or manuial, if auto probably tick over is to high shud b about 750-800 rpm but set till it just holds car steady no creeping back or forward, manclutch adjust ment worn slave cylinder or peadle adjustment good luck hope this helps
Nov 09, 2013 | 1999 Lincoln Town Car
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
I purchsed this monitor at a thrift store. It
Is your remote working? If so use the key pad and open up the menu- look for advanced settings, press unlock (parental controls) also use the default setting to auto reset the channels....
May 29, 2010 | Kogi L7CH Monitor
Constantly refocuses while taking video
If you aren't planning on zooming in or out, you can lock the AutoFocus by:
- first assign the shortcut key to the AFL (Auto Focus Lock) setting (by going to Menu, then "Set Shortcut button") - then while filming, press the shortcut key (which you have assigned to the AFL setting) and the focus will adjust and unlock (the AF will unlock when you press any other button). - each press of the shortcut key will adjust and lock the focus
Dec 20, 2009 | Canon PowerShot SX20 IS Digital Camera
Front brake rotor on 1992 Ford Ranger 4wd with auto lock in
With Automatic Locking Hubs
  1. Raise the vehicle and install safety stands.
  2. Remove the wheel lugnuts and the wheel and tire assembly.
  3. Remove the retainer washers from the lugnut studs. Remove the automatic locking hub assembly from the spindle.
  4. Remove the snap ring from the end of the spindle shaft.
  5. Remove the axle shaft spacer
  6. Being careful not to damage the plastic moving cam or thrust spacers, pull cam assembly off the wheel bearing adjusting nut and remove the two plastic thrust spacers from the adjusting nut. CAUTION: Do not pry on the plastic cam or thrust spacers during removal. Prying may damage the cam or spacers.
  7. Using a magnet, remove the locking key. NOTE: If required, rotate the adjusting nut slightly to relieve pressure against the locking key, before the key can be removed. CAUTION: To prevent damage to the spindle threads, look into the spindle keyway under the adjusting nut and remove the separate locking key before removing the adjusting nut.
  8. Loosen the wheel bearing adjusting nut from the spindle using a 2-3/8 inch Hex Locknut Wrench T70T-4252-B or equivalent.
  9. While rotating the hub and rotor assembly, tighten the wheel bearing adjusting nut to 47 Nm (35 ft lb) to seat the bearings. Spin the rotor and back off the nut one-quarter turn (90 degrees).
  10. Retighten the adjusting nut to 1.8 Nm (16 in lb) using a torque wrench.
  11. Align the closest lug in the wheel bearing adjusting nut with the center of the spindle keyway slot. Advance the nut to the next lug if required. Install the separate locking key in the spindle keyway under the adjusting nut. WARNING: Extreme care must be taken when aligning the spindle nut adjustment lug with the center of the spindle keyway slot to prevent damage to the separate locking key. The wheel and tire assembly may come off while the vehicle is in motion if the key is damaged.
  12. Install the two thrust spacers and push or press the cam assembly onto the locknut by lining up the key in the fixed cam with the spindle keyway. CAUTION: Extreme care must be taken when aligning the fixed cam key with the spindle keyway to prevent damage to the fixed cam.
  13. Install the axle shaft spacer.
  14. Clip the snap ring onto the end of the spindle shaft.
  15. Install the automatic locking hub assembly over the spindle by lining up the three hub assembly legs with three pockets in cam assembly. Install the retainer washers.
  16. Install the wheel and tire assembly. Install and tighten lugnuts to 135 Nm (100 ft lb).
  17. Make sure the final end play of the wheel on the spindle is 0.00-0.08 mm (0.000-0.003 inch). the maximum torque to rotate the hub is 2.8 Nm (25 in lb).
Jul 27, 2009 | 1992 Ford Ranger
Auto door locking on Ford Mondeo
It sounds like it has been deactivated so we are going to reactivate the auto lock.
The numbers I will be saying will have to do with getting this to work so:
you will need to put the key in to the ignition switch.
1= is back to listen to the radio
2= is to get key out
3= is just before you start
4= is for starting your car
When we do this 1 and 4 will not be used
Do this and we will hope that it works like it should:
1: Turn the ignition with you key up to on( don't start)
2: Press the power door lock control 3 times
3: now turn the key back once (to off position)
4: Press the power door unlock control 3 times
5: ok turn the ignition back up 1 time. (The horn should chirp)
6: Then press the unlock control, then press the lock control, again (horn will chirp 1's) If auto lock
was activated.
7: Turn the ignition back 1's, Then the horn should chirp once to confirm the procedure was completed.
Nikki2913
Nov 23, 2008 | 2006 Ford Focus
Tuning,auto search mode lock
I need a copy of the codes for the rca remote
Oct 27, 2008 | RCA RCR311B Remote Control
Samsung 731N Auto Adjustment
Hold menu button for 5-6 sec.
Enable od disable this funnction.
Nov 18, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Samsung B2030 LCD Monitor Logo
174 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
