Question about APC UPS: UP BP420S w/Powerchute (UPSAPC26AS) UPS System
Wat is the problem of ups model su1400rm12u smart ups when i turn on the ups it cant go to normal operation.. the led of the front it lights all.. wat is the problem?
I have an apc smart ups su1400rm12u when i on the ups after some time all lights start blinking and output fail
Posted on Aug 03, 2013
    Problem Solver:
  • 9 Answers
Problem in the inverter
Posted on Apr 19, 2011
Volume goes up and down at will
Incedental lighting can affect the IRD receiver module on the front of the TV. Try blocking all source of energy with black tape to prove this. If no effect then you may have to reset the TV or reprogram the input device, cable, on air etc....
Jun 29, 2015 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Remote control not working
vizio remotes are junk. I have 70 inch led smart tv and both remotes are junk. I have no idea what brand is better to replace it with.,
Sep 19, 2014 | Vizio M422I-B1 42IN LED LCD Smart TV Full...
What does it mean when a,b,c, and d turn green on the back of a dell dimension 2400. the power light on the front of the case is green but th other one is amber
the information is here
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
the ABCD leds indicate the progress of the power on self test (POST) GGGG LEDs indicate POST has passed and the operation has been passed from the BIOS to WIndows
Green power led on front indicate normal operation. the other LED is likely the HDD activity LED
Jan 21, 2011 | Dell Dimension 2400 PC Desktop
How to connect a UPS to a computer? why some UPS with RS-232 port some UPS not? What is difference from APC smart UPS and normal APC UPS? Why APC with same VA output, but the price is so much difference?
A UPS goes between the Power Socket and the PC equipment.
So ya can "Talk" to the UPS and change monitor settings. So do some don't depends wat ya want?
A "Smart" one is computer controlled, and most probably ya can "Talk" to it, the other is the "Vanilla" model, real plain.
More Complex.
Jan 26, 2010 | APC Smart-UPS 1000VA UPS System
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
THE EXACT SAME, NO POWER NO GREEN LIGHT
I have a similar problem in that when I turn the switch on the back on, the green led at the front blinks once and then stays dead.
If I put my hand over the IR pod [block all light from it] and then turn the back switch on, the led blinks once and then goes into standby mode and from then I can turn it on normally with the remote etc.
Weird hey.
Jun 28, 2009 | Altec Lansing VS3251 Speaker
APC smart ups 1000va
Here we go again.. i encouter a lot of this problem. just change the whole front panel board and everything will work fine.
Jun 11, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
I have a 32" Insignia TV (IS-LCDTV32. In normal operation, when TV is off, the LED on the front is solid red. In normal operation when I turn teh TV on, the LED turns blue and the TV turns on. In the...
If your LCD is less then a year old, I would suggest to contact the manufacturers to have it fix under warranty.
The failure on your LCD could be a defective back light inverter or a power supply not providing enough power to the back light inverter board.
Let me know if you require further assistance.
Oct 14, 2008 | Televison & Video
Question about APC Smart-UPS 1400
This is the battery you need to replace http://www.batterywholesale.com/battery-store/proddetail.html?prodID=619
Ther are a few places to get one
Nov 03, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
APC UPS: UP BP420S w/Powerchute (UPSAPC26AS) UPS System Logo
500 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
