Question about Sony Vaio PCG 7Z1M Laptop Universal AC Adapter 1820v
My sony vaio charger is got pulled out one day by kids running around, and when I went to plug it back in it would only work if i have it a certain way. I went out and bought a universal charger that said it was compatible with Sony Vaio only to bring it home and have it not work, Is there a reason for this? and is there anything I can do that will make it work on a students income?
    Scholar:
  • 78 Answers
You mentioned that when you plugged in back the charger, it worked if you try moving it right? chances are, the problem could be with the charging pin itself of the laptop. there might be a loosening due to the sudden pulling out of the charger..
Posted on Apr 10, 2011
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
Computer will not power up..Upon initial start , went into hibernating mode then never started up.
Hi
Please can you try the following
1) Remove battery and wall charger
2) Press and hold the power button down for 30 seconds
3) Plug charger and battery back in
4) Retry powering the laptop
Regards
Shauqat
Apr 19, 2010 | Sony VAIO VGN-S460 Notebook
Hullo, I spilled wine on my sony vaio
spilling the wine could have caused a surge to your battery or charger either one could be damaged but if your battery is reading full and powers off at random then it is probably your battery and needs to be replaced
Apr 08, 2010 | Sony VAIO VGN-N250E/W Notebook
My compute went off the other day now i have no power its not the charger?
if its not the charger then you have a problem with the power IC.A hardware engineer need to examine it.i hope this helps
Sep 14, 2009 | Sony VAIO VGN-FJ270/B Notebook
Power chord problem
(1) Does the machine work with the cord plugged, if so it is the battery or the charger circuit at fault
(2) If it does not work then there is either a break in the cable where it enters the plug which plugs into the back of the laptop or the power supply has failed
Aug 31, 2009 | Sony VAIO VGN-NR430E/S NoteBook
Laptop Battery Wont Hold Charge
change original battery. check dc jack charger.
Jun 02, 2009 | Sony VAIO Notebook
Cant find a kid trax battery charger
Here 12V Battery Charger for Kid Trax Riding Toys Dodge Ram Dodge Charger... you can purchase the charger from amazon. I hope this was helpful. Have a nice day
Apr 19, 2009 | Toys
Problem in hardware in sony vaio VGN-CR220E laptop computer
It should power on when plugged in, even if the battery is pulled out of the laptop.Try holding the power button down for 10 seconds to see if it boots up when its plugged in.
Feb 08, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony Vaio PCG 7Z1M Laptop Universal AC Adapter 1820v Logo
102 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
