Question about Sentry Fireproof Safe
I think the gears are stripped on the handle and i cannot get safe open HELP
2 Suggested Answers
SOURCE: i have a sentry fire safe and the plastic gear
If someone attempts to open the locked safe by forcing the safe handle to the open position it can strip the plastic gear. So even if you have the correct safe code and the batteries are fully charged the safe will not open. If you can lay the safe on its side (hinge side on the floor) gravity and banging the side of the safe with a hammer may cause the bolts to unlock. Unfortunately, if this doesn't work you will need a locksmith to open the safe.
Good luck.
Terry Whin-Yates BA Hons (Criminology)
3rd Generation Master Locksmith
25+ Years Experience
BC Security License : B4227
604-773-5625
http://www.mrlocksmith.com/
Posted on Dec 28, 2010
P-45c shreeder motor runs but blades do not turn got all paper out but still do not turn
David,
More than likely, you have stripped the plastic gear inside. Those gears can sometimes be difficult to find and purchase. I would suggest trying to open up the top so that you can confirm if the gear is stripped. I would also suggest not putting as much paper through the shredder as they say it will handle. Hope this helps!
May 20, 2015 | Fellowes Office Equipment & Supplies
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
I have a sentry fire safe and the plastic gear where the handle turns the safe open has been stripped. I have the correct combination and have replaced the batteries but i cannot get the safe to open
Good luck.
604-773-5625
Nov 24, 2010 | Sentry Safe Fire-Safe Home/Office Safe
My crafstman garage door opener goes down and then
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Passenger inside door handle is stuck halfway out.can't unlock or
gear on door handle prob stripped.. get new handle and install their around 20 dollars
Mar 06, 2010 | 1998 Ford Explorer
First plastic gear driven from motor pinion has
I have a simple solution if you can think outside of the box. When my gear stripped, I chucked away the electrics, and now drive the shredder via a crank handle on the side. It gives good excercise, and isn't difficult to turn with anything up to 6 or so sheets.
If you want to do this, open the machine, and remove the smaller gear at the opposite end of the drive (take off the circlip) to expose a hex shaped shaft. You can also chuck all of the electrics, and all but the two gears that are on the shredder shafts. Then cut a hole through both the top casing, and through the bucket, to line up with the shaft end and allow a 9/16 socket to pass through. When reassembled, there is sufficient room to drive the mechanism with a standard 3/8 drive ratchet, although you could make a fancier drive with a handle on.
Happy Days
Garry
Feb 05, 2010 | Fellowes P400C-2 Shredder
Driver door will not open from inside
Your inside door handle is probably broken. The gear has stripped causing it not to work. Remove the door panel to verify the rod for the inside handle is not moving. .
Feb 03, 2009 | 2000 Ford Expedition
Manual Window won't roll down
the gear probably stripped out on the handle.you can buy a new handle at any parts store.
Jan 17, 2009 | 2004 Chevrolet Cavalier
Sentry Fireproof Safe Logo
100 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
