Question about Nokia XpressRadio 5030 Cell Phone
Nokia 5030 the flash light is always on, it could not be switched off. when we switch it on it glows with more light and when i switch it off it glows with minimum light. What should i do to switch it off?
  • 37 Answers
SOURCE: The camera light is always ON even after switching the phone OFF.
better check out your firmware or take it to a neraby specilist
Posted on Sep 15, 2009
blindmurder2
  • 92 Answers
SOURCE: nokia 3110c unable to switch on
reinstall your mobile software.........go to market and tell them to install your new mobile software
Posted on Dec 17, 2009
  • 821 Answers
SOURCE: Nokia 5030 phone slightly dipped in sea. Now it is
hello,all you need to do first is to sun dry the phone to make sure alll the components are dry or you put it closer to a bulb to make it dry very well,after that is done you then get a tooth brush that is kind of soft and get methylated spirit to clean the sim slot thoroughly,after that you insert your sim and see if the same problem still persist,if it does you will need to replace the sim slot to make the phone function as required.
then the issue of the touch glowing,you will do as aforesaid to sun dry it that should revive the stability of the torch light,,and if it doesn't you will have to get as new bulb to replace the glowing one.if you are not technically sound,i will advice you take it to an authorized expert to help you fix it properly.hope this helps,
please if it's helpful,kindly rate the solution,
take care.
Posted on Jun 09, 2010
caroldon
  • 17130 Answers
SOURCE: my nokia 7210 supernova always get switched off
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone.Make sure the battery is connecting tightly to the contacts. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Feb 03, 2011
Prof  Henry
  • 209 Answers
SOURCE: Nokia 5030 display light always on??
It has virus, format or flash it with a computer. Thank you for using Fixya.
Posted on Aug 29, 2011
WOULD YOU PLEASE SOLVE MY PROBLEM ON BACKLIGHT NOT GLOWING OF NOKIA 5030C-2?
If there is no option to switch the backlight on/off then, its probably a hardware problem so it will be best to go for nokia care or other authorised or expert nokia hardware technician..
Oct 24, 2011 | Nokia XpressRadio 5030 Cell Phone
Nokia 5030 have always light on
What do you mean" Backlight"? If backlight does not go off just restore it.Open Menu>>Setting>Restore factory setting>>.This trick is working in Nokia 1600,1200 1110, etc.etc,This may help you thanks for visiting fixya.
Sep 02, 2011 | Nokia XpressRadio 5030 Cell Phone
Aug 29, 2011 | Nokia XpressRadio 5030 Cell Phone
When i make a call from my nokia 5030 the mobile start to switched off
I had the same problem with my Nokia 5800 XM, try to download Nokia Ovi Suite (from nokia.com) and connect your phone through USB. Try to update the firmware of the phone, after that it should run faster and more stable.
May 05, 2011 | Nokia XpressRadio 5030 Cell Phone
My Nokia 5030 was drenched in little water. I didn't notice that the flash light was turned on automatically. After 2 hours I noticed that flashlight was on continuously. It has been 3 days, light is still...
Dear User,
you should have dried the phone by removing all panels , battery and SIM, still try doing this immediately , dry it in a place where temperature is about +40 C, but never too high! if it does not get ok, you may need to send phone for repairs.
May 04, 2011 | Cell Phones
Have you an unlocking codes for nokia 5030
Nokia 5030 Xpress Radio Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia 5030 Xpress Radio mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5030 Xpress Radio mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5030 Xpress Radio without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5030 Xpress Radio.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5030 Xpress Radio would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5030 Xpress Radio mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5030 Xpress Radio
Each Nokia 5030 Xpress Radio mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5030 Xpress Radio mobile phone using the form above.
Jan 30, 2011 | Cell Phones
Nokia 5030 phone slightly dipped in sea. Now it is asking insert sim and the torch light glows continously.what would be the problem.how can i solve it?
take care.
Jun 09, 2010 | Nokia XpressRadio 5030 Cell Phone
Generic problem for all Cellular Phones How to unlock a nokia 5030 for free Ads by Google
Mar 11, 2010 | Cell Phones
Hi 5030 contact service plz help me
nokia 5030 contecte service solotion
Feb 01, 2010 | Nokia 6300 Cellular Phone
Nokia XpressRadio 5030 Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
