Question about Roper Dryers
Makes a terrible shriek noise when you start it.
  • Roper Master
  • 7,482 Answers
You could have a belt slipping or drum rollers beginning to make noise.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather-proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 09, 2011
2007 Cadillac escalade makes loud noise when starting the car. Sounds like the air suspension on a navigator when it adjusts, but louder. Lasts maybe 20 seconds. Happened 3-4 times within the year. Any...
Try to better describe the noise.
Is it a
scraping of metal
grinding / rubbing
high pitched shriek like a drive belt slipping
Is it
underneath the body
under the hood
in the aircon
when you pull into gear
when you pull away
etc
Do a bit of detective work and come back.
Sep 28, 2013 | Cars & Trucks
The bike makes a shrieking noise wen i pull away and a meshing noise is it the clutch
You should go back and review your work. Shrieking noises are not friendly. Oil ok? Proper adjustments? Proper parts in the proper order? All fasteners properly installed? All parts accounted for?
Feb 24, 2013 | 1998 Yamaha XVS 650 Dragstar
Maytag Model SDG3606AWW slow to start, shrieks when running
T"he sound you are hearing is coming from the blower wheel.This is located in the front of the machine and can be accessed by removing the front of the machine, Getting the front off varies machine to machine, Once the front is off, you'll see the blower wheel in the front, and once again some models you may have to remove exhaust vent, in others just the cover of the blower wheel. This is an easy repair, no doubt. The part number is 56000
Jun 03, 2012 | Maytag Dryers
I have a 2007 ford expedition eddie bauer and when I start it up it makes this loud noise as if something is wrong with the starter. It is not a shrieking or whining noise.This only happens when I start...
I have similar issue with a 2008... here's a link so you can see the noise it makes. Please let me know if it's similar to yours. I am working on a solution and would be happy to share it with you if I find it.
http://www.youtube.com/watch?v=wn9vK3-CNig
http://www.ford-forums.com/new-member-area/52583-2008-expedition-rattling-noise-when-starting.html#post200877
Jun 30, 2010 | 2007 Ford Expedition EL XLT
Dell Studio 1737's power pack makes a shrieking, humming noise
I would stop using the adapter immediately. It could be about to blow. When one of these blows, you can get smoke, sparks and fire. You don't want that to happen when you are not around. Further you don't want to have a voltage spike from the adapter to *********** board. You can buy a new adapter at Walmart or whereever. Just be sure that it supports Dell computers. Dell uses a third pin frequently. Check the voltage and amperage of your current adapter. You should see something like 19V and 3 Amps. Make sure that your replacement adapter works within those rages.
You can also buy an exact match from Dell or ebay.
Expect a good Universal adapter that you buy at Walmart to be in the range of 50-100.
The good thing about a universal adapter is that you can use it on another notebook later.
May 22, 2010 | Dell Studio 1737 Laptop
Makes a shrieking noise about once a revolution
sounds like a belt but need more info
Oct 17, 2009 | Dryers
Noise from dishwasher
Dishwasher makes loud noise in begining. How do I remove lower spray arm to see if something is stuck? Whirlpool DU1055xtpb4.
Jan 14, 2009 | Whirlpool Dishwashers
L MARK shrieking noise
No, do not spray oil on your belts. Have the belt replaced if that's where the noise is coming from. The squeaky belt could also indicate one of the accessories may be bad. Have who ever replacing the belt check to make sure all the accessory pulleys turn freely.
May 14, 2008 | 2005 Lincoln Mark
Dryers Logo
49 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
