Question about Exercise & Fitness
The motor shots down quick when starting it - Exercise & Fitness
    Problem Solver:
  • 14 Answers
Lower electronics board failure. Your treadmill walking belt is probably way overdue. You have worn out the electronics. Replace your belt, flip the deck if applicable(replace mylar if present), and replace lower electronics.
Posted on Apr 09, 2011
My 2002 Kia sedona van was going down highway , it made a grinding sound , motor died , now starter just clicks, motor won't turn over : whats could be the problem ?
Starter clicking, not enough power to turn motor over. Check the battery, make sure charge is full. If it is, your starter is shot, replace it
Apr 16, 2014 | 2002 Kia Sedona
Motor pop when down shift
Generally popping on deceleration is caused by a lean condition, or a air leak in exhaust manifold or intake manifold or corn boots. Check for intake vacuum leak around the carb flanges and any intake gaskets with a quick shot of carb cleaner while running. A leak will change the engine rpm. Listn carefully for exhaust manifold leaks and 11_12_2013_4_27_36_am.png
Aug 28, 2013 | Motorcycles
I have a 2002 chev silverado 2500HD duramax 4x4, The truck starts only when given a shot of quick start in the airbox. After it runs great you can shut it off then re start it fine. It will not start...
You need new glow plugs. Im guessing you live somewhere kind of cold maybe. It starts just fine after running because the motor is already warm. Quick start will work.....or at least it did for me until I used one mornig and went to crank and BOOM. It blew my air filter case to pieces and caught the filter on fire. Starting fluid is not meant for diesel motors. If you cant afford new glow plugs what worked for me is turn on the key all the way but dont crank wait 10 sec then repeat a few times and it should crank unless its really cold out or the plugs are really bad. Trust me thats what it is. I replaced mine and now It cranks right up even when its super cold.
May 09, 2011 | 2002 Chevrolet Silverado 2500HD
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
When i press the start buttom it's not doing anything just i hear a click sound coming out from where the fuse is., so i got use foot starter. hanks if anyone knows what it could be...
The sound your hearing is proberbly the click of the starter solinoid.
Nothing else happens hay?
This sounds like your starter motor is faulty!
To do a quick test try placing a jumper lead from your Battery POSATIVE straight to the starter motor cable.(there may be a spark but don't be too scared). Hold there for a couple of seconds.
If you don't hear the starter motor spin you have a shot starter motor.
This should help
Regards Andrew Porrelli
Dec 08, 2009 | 2005 Husqvarna TE 450
My 1997 discovery land rover is over heating, every 20 minutes or so, its starts to over heat, what could it be? would the motor be totally shot?
The motor is not totally shot. Here is a short checklist for you to go down to find your problem:
  1. Check your coolant level to make sure it is full. If it's not it will cause overheating
  2. Change your thermostat, they go bad and stop opening properly and need to be replaced.
  3. Check radiator fan to see if it is functioning properly.
  4. Check lower radiator hose to see if it is still solid. If it is "mushy" it can sometimes close up when the fluid is trying to flow.
Let me know what you find when checking these and thanks for using FixYa!
Jul 07, 2009 | 1999 Land Rover Discovery
I need super cheats of cricket 2005?
Getting the opposition out quicklyTry bringing the medium fast or medium bowler on. Then, place the bowling marker just short of the good length spot or even further down towards the bowler. Try inswing ball or outswing but drop the speed to almost nil. Keep the speed to two or three lines (yellow meter). The batsman will play a backfoot defensive shot and eventually get bowled or LBW.
A second way of getting the batsman out quickly is bring the medium fast or fast bowler and try bowling inswing bouncer and place a fileder at deep thirdman for a catch. This trick only works when the batsman is new to the crease or tailenders.
Votes: 1 100% 0%
Easy run outs
Go to "My Cricket" then click "Game Settings". Set "Auto Fielding" to "Manual Fielding". Then, start a match and choose a fast bowler. Change the field by using "Field Editor" and select "Retreat 3:. Bowl out side offstump batsman will defence. Do not get to the ball immediately. Wait for two or three seconds. The batsman will run. Go and pick the ball and press [Space] + S for hitting a direct aim at non-strikers end or [Space] + W for hitting a direct aim at strikers end. Most of the times the batsman will be out. Note: Be patient as the batsmen will not not run sometimes.
Votes: 1 0% 100%
Easy six shots
The more you play, the more you will master the game. It is not easy to start hitting six shots from the start. Even after much practice you will find it difficult to play the all the shots. The best way is to play six shots down on the long on and long off boundary using [Down] + [Shift] + S. Players who have good calibre like Sachin Tendulkar, Virender Sehwag, etc. will be find it difficult to hit six shots. If you try with other players you may end up with a mis-timed shot and give a catch. If bowled onto the stumps, for beginners play it down the legside using S + [Right].
Votes: 0 0% 0%
Easy six shots
Votes: 1 100% 0%
Keeping the scoreboard moving or hitting some runs
Always bring the left handed batsman first and aim for the leg side boundary for six hit shot. He will succeed many times.
In test matches, do not rush for runs or you will get out very quickly. Place your innings and play the ball in the gaps.
Votes: 0 0% 0%
Get batsmen out fast
Bring in a fast bowler (for example, McGrath) and aim a normal delivery behind either the middle or the off stump. Put the bar up to almost full power and let her rip. Most batters will swing and miss or be caught LBW.
When bowling with someone who has a slower ball (for example, McGrath put the pointer as near to the bowler as possible, then put the pointer just to the left of the umpire. Put the power to two yellow bars. Then watch them walking in and out of the Pavillion.
Votes: 0 0% 0%
Easy six
When the ball is pitched just in front of your leg outside offstump or towards middle stump, sweep it through the legside by a powershot. Most of the time the result will be a six.
Votes: 0 0% 0%
How to make the opposition out in 20/20 matches
Normally in 20/20 cricket in this game when you are playing against a strong team like Australia they remain in 15 overs at about 130 for no loss. But to make all the batsmen out quickly after 15 overs choose a pace bowler( For example Irfan Pathan ) and place the ball mark after the middle stump and make tsure the ball speed is full. Then the batsmen will become bowled or caught at long on or Long off.
Note:
1. This will only work on pace bowlers
2. this might only work if the game is et in easy mode
Good Luck
Dec 11, 2008 | EA Sports Cricket 2005 for Windows
Roper dryer
Replace the motor, the run winding is shot.It is not hard to replace the motor. The blower has reverse threads(righty loosy). The motor has a quick connect(no wiring needed). Yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way.Get the idler loose and remove the drum. Clean it all up and replace the motor. I can do it in 20 minutes. It is simple and uncomplicated. Go for it.
Dec 01, 2008 | Roper REX4634KQ Electric Dryer
Exercise & Fitness Logo
60 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
