Question about Mtd Garden
We have just bought a ride on mower which is in pieces as a project. The serial number is 136M760N608, which we were told is an MTD. Other numbers on show are N145/102. The engine is a briggs & stratton 14.5 HP. We cannot find a manual anywhere! Can you help us to identify this machine and find the right manuals? Many thanks
kevin000
  • 1847 Answers
SOURCE: Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Posted on Sep 24, 2008
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 376 Answers
SOURCE: can't find location of oil filter on engine, manual shows where it should be but it's not there. Model#
If your model # ends in 707, as in 42A707, it does not have an oil filter. You would see it sticking out of the left side if it had one, as in 42A777. You have an opposed twin,a very good engine, unfortunatly, not made anymore. Most of them did not have an oil filter. Dwain
Posted on May 26, 2009
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
We are needing a Deck Belt/blade belt part number unknown for a MTD Yardman 13AT604G671
Go to MTD website with your Model and serial number and see if you can download a manual for this tractor.
May 23, 2014 | Mtd Garden
Need an Owners Manual for my 17.5 hp 42" cut Pony Troy bilt riding mower, Model 13AN779G766183630 Serial 1E045B30725000004
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Sep 01, 2011 | Mtd Gold 13AA625P004 50Inch 502cc 230 HP...
Were is the model number located on a 14hp 42" mower deck?
The model number for your mower should be under the seat on a tag that has the model number and serial number of your machine.
Jul 21, 2011 | Mtd Drive Belt 42"
Need a manual for a Model 13AF608G062, Serial #1E292H10446 MTD Yardly Riding Mower
If you go to the MTD website you can enter your model and serial number and you will be able to download your manual.
here's the link - http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Jul 18, 2011 | Yard Machines Garden
Mtd mower model 13ah660f352 need a place to get a free download for the manual
http://manuals.mtdproducts.com/mtd/Public.do
If you can't find your serial number just enter some 1's but better to have your serial number.
Aug 19, 2010 | Mtd Garden
3.5 horse power rideing lawn mower 638 R L yard machine by M T D
There is no such thing as a 3,5 hp riding mower,a serial number or a model number would help,along with an actual question.
May 17, 2010 | Mtd Garden
MTD Products- Yardman
The part number is 770.8637M, You can find it at www.mtd.com, click on yardman logo, click on owner's manual. Put in Model # 13ag675g196, Serial # 1a027130180. It will bring up the manual you are looking for.
Merry Christmas
Dec 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I need a diagram showing how to put the drive belt back on a riding lawn mower MTD model 13A869F190
I'm having trouble with the number you provided. Please revisit your mower and obtain the model number and serial number, then click on this link:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10301&LeftNav=true&langId=-1#
Type in your info to obtain your users manual for your mower. It should contain the belt routing diagram you're looking for.
Hope this helps... Good luck!
Aug 06, 2009 | Mtd Garden
Replace transmission belt on my 42" MTD Mower
You can download a manual here:
You will need the model & serial numbers.
Jun 01, 2009 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
