Question about As Seen On TV Finishing Touch Hair Trimmer
How do I change the battery in my Finishing Touch Pro?
How to change the battery in finishing touch
how to change the battery in finishing touch by diamond
Oct 09, 2016 | As Seen On TV Finishing Touch Hair Trimmer
Tip
How to change your iPod touch and iPhone battery
Batteries for the iPod touch, iPhone, and much more can be purchased from http://www.milliamp.com
Using a thin, but sturdy guitar pick, carefully separate the backing of the iPod from the screen. This may be tough to do because the chrome backing snaps to the touch screen assembly, and care must be taken to prevent cracking the screen.
Once the chrome backing is separated from the iPod, the battery is now exposed.
If the battery has never been changed, it will more than likely be glued in place, and must be carefully removed with the guitar pick as well.
The wires must be soldered and taped with electrical tape, or carefully protected with heat shrink tubing. There is not much clearance available inside the iPod, so keep this in mind when finishing up with the wiring and protecting the wires from shorting.
Carefully put the new battery in the old batteries spot, and snap the chrome backing back together with the front screen.
Charge the iPod for at least 10 minutes before attempting to turn it on, but keep it on the charger until it is fully charged for best results.
on Jan 12, 2010 | Apple iPod touch
Officejet Pro K550 text prints grey instead of black
go to the printer control panel, right click your printer and open preference or may be properties on your end, Click the Color tab, and change the color option to black or color. hope this helps. feel free to rate how helpful it is.
Oct 07, 2010 | HP OfficeJet Pro k550 Printer
HTC touch pro battery don't last
download advanced task killer free this will save your battery, it kills all the programs running in the background that you are not using at the time and will save your battery life it's a free program and very useful, look for it in the andriod market in apps
Jan 12, 2010 | HTC Touch Pro Smartphone
My htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Sep 25, 2009 | HTC Touch Pro Smartphone
Slide out keyboard not working on HTC Touch Pro
Take the battery out of the TP and then press down very hard on the spacebar. This will reconnect the flex cable and will fix it for the time being. But in the end a replacement will be needed.
Jul 27, 2009 | HTC Touch Pro Smartphone
My HTC Touch Pro turns completely off in the middle of the night
I think I have found out the way to solve this problem! I think! Ok on my phone I changed the power settings. Go to settings>all settings(if on touch flo)>system tab>power>advanced tab> then uncheck the two boxes that says "turn off device if not used for". Hopefully this works because I don't want to trade in my htc for another phone. Try it out and let me know if this works for you or not.
Mar 30, 2009 | HTC Touch Pro Smartphone
Touch pro
This is a software issue. Take out the battery and wait shortly 30 seconds. Replace battery and boot up PDA. If issue is still unresolved, visit your nearest carrier's repair center for a "manual hard-ware reset".
Mar 13, 2009 | HTC Touch Pro Smartphone
Hang
mayb you should do a hard reset on your phone.SYSTEM CRASHED.And mind to inform you that try to not install too many 3rd party application.
Dec 28, 2008 | HTC Touch P3450 Smartphone
As Seen On TV Finishing Touch Hair Trimmer Logo
793 people viewed this question
Top As Seen On TV Health & Beauty Experts
Tom Chichester
K McMurdo
Are you an As Seen On TV Health and Beauty Expert? Answer questions, earn points and help others
