Question about Samsung Office Equipment & Supplies
My scanner not working,while the printer &fax are ok,my machine brand scx4216f
    Scholar:
  • 111 Answers
Looks like the driver for the scanner is damaged, you need to download the new driver from samsung web side and install it on your computer then it will work.
Posted on Apr 10, 2011
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
I want a driver software to scan from this printer scx4216f samsung
Driver software for the SCX4216F Samsung printer can be found at the following
website http://driverscollection.com/?H=SCX-4216F&By=Samsung
Follow all of the instructions on the site for proper downloading of the software.
Jan 21, 2011 | Computers & Internet
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Do i need an ink cartridge for the fax machine to work and setup
Some brands of fax machines and all-in-one printer/scanner/fax/copiers need the ink cartridge to be present and have some ink in it to perform functions which don't actually require ink.
My dad bought a Brother all-in-one, and he is unable to scan or send faxes unless he replaces an empty ink cartridge first. If you have a Brother fax machine, I'd suggest returning it and buying a different brand. They waste ink on unnecessary cleaning procedures and force you to buy more for stuff that doesn't need ink.
Mar 03, 2010 | Samsung SF-3200 Fax
Scanner locked - samsung scx4216f
its may be the problem related to its Scanner Cable.
Remove the Scanner cable
Feb 24, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Won't copy or fax, scanner failure
Uneconomical to replace the scanner assy. sorry
Feb 17, 2009 | HP Officejet 4315 All-in-One Printer
Fax mystery
I am having the same problem as you. I think that we need to activate the confirmation sheet but i dont know how to do it. Did you fix it ???
Thanks in advance,
_ting_
Jan 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
Fax machine problem
i can tell it is a Hardware problem. sounds like mark on drum unit, pull it out and inspect it, slight chance it is toner cart or fuser assy
TRE
Oct 31, 2007 | Samsung SCX-4216F All-In-One Laser Printer
47 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
