Question about Ubi Soft Catz 5 (Windows) (680901) for PC
I'm trying to install catz 5 on my computer and it gets to 50% while uploading it and then it stop and says: component: shared 2 file group: are file group file: D:\data2.cab error: data error (cyclic redundancy check) then it tells me to fix the problem and try installing it again. But what is the problem and how do i fix it?! please help if you can xx
    Genius:
  • 1,479 Answers
From my experience, a cyclic redundancy check error is a problem on the instal disc. You need to return the disc to the supplier for exchange.
Posted on Apr 09, 2011
  • kateprimrose Apr 09, 2011
    oh bum. you see i got it on ebay, so if that is the case i will be extremely annoyed
Catz 5 Won't Uninstall :
Try software Revo uninstaller it will hunt those files
Oct 14, 2016 | Ubi Soft Catz 5 (Windows) (680901) for PC
Dear Sir/Madam, Having installed XP 5 years ago. I founded some of problem previously, such that, perform reinstall XP, meanwhile, I can't get back my data when reinstallation. And, I tried to change...
Please, try the following depending on the XP version you have:
For Windows XP Professional Edition, disable Simple file sharing:
Click Start, and then click My Computer. On the Tools menu, click Folder Options, and then click the View tab. In the Advanced Settings section, clear the Use simple file sharing (Recommended) check box. Click OK. Then, follow these steps:
  • Right-click the folder in question, and choose Properties.
  • Click the Security tab.
  • Click Add, and type in Administrators, click OK.
  • Select Administrators group that you've added now.
  • Put a checkmark near Full Control (Allow) in Permissions box.
  • Click OK.
For Windows XP Home Edition, you need to start Windows in Safe Mode in order to see the Security tab. Remaining steps are the same.
Once you add Administrators group and give them Full Control for the folder, theMake this Folder Private option is automatically disabled. Level 1 permissions are no longer in action.
Mar 21, 2011 | Microsoft Computers & Internet
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
Dogz 5 not installing!!
then the problem is not with ur computer but with ur cd. use isobuster and create an image of the cd. then mount it. now u can run and install it. there is an easier way get a new copy of the software
Feb 12, 2010 | Ubi Soft Catz 5 (Windows) (680901) for PC
Catz 5 problem with installation.
that has happened to me before!! try downloading catz 5 from the internet or try installing it on another computer.
Jun 02, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
Cannot install or play Petz 5!!!
Delete or rename Program FIles\Common Files\Installshield I did that and it works.
Dec 12, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
When I put in my Catz5 CD, the installation window doesnt pop up?
http://www.revouninstaller.com/revo_uninstaller_free_download.html
download revo uninstaller then install form here.
then uninstall with this software your dogz 5.
moderate and dellete all key which it say.
then install again.
Nov 19, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
File sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
Jul 05, 2008 | Microsoft Windows 2000 for PC
if you are trying to install the game from a CD or DVD the cause could probably be that the CD or DVD is damaged, try cleaning the media. if u are trying to install the game from a cd or dvd try coppying all the files on to your had disk and then open the setup procees from the hard disk.
Jun 12, 2007 | Ubi Soft Catz 5 (Windows) (680901) for PC
Open Questions:
See all Ubi Soft Catz 5 (Windows) (680901) for PC Questions
Ubi Soft Catz 5 (Windows) (680901) for PC Logo
166 people viewed this question
Top Ubi Soft Computers & Internet Experts
Pavel Pranovich
Pavel Pranovich
k24674
tony wahlman
tony wahlman
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
