Question about Craftsman Garden
My craftsman riding lawnmower 42"
  • 43,501 Answers
The first thing to check is the wheels on the back corners of the deck....amke sure that they are set at the same height and that the bearings are not out of the wheel, which would allow the deck to sink lower on one side.
If all of that checks out then you have problems under the deck....
The bearings that hold the blades can wear allowing one of the blades to drop, or one of the blades could be bent which could cause it to cut lower...to fix that bearings will have to be replaced or the blades will have to be replaced if bent.....
These would be the causes for your mower to cut unevenly...
heatman101
Posted on Apr 09, 2011
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Jun 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Aug 26, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
One blade on deck gives an uneven cut
Sounds like a bent shaft, or the mounting is not flush.
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
118 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
