Question about Dryers
When turning the cycle settings knob, the dryer makes an immediate electrical hum as if the motor had been started but was unable to turn. This occurs before the actual start knob is turned
  • 3 more comments
  • kford327 Apr 09, 2011
    This is a hotpoint model NVLR333ET0WB. S/N is HS223472H
    It hums like a start capacitor has failed, but I have no reference to indicate whether it has one, and even so, the start switch hasn't been turned to start, so it shouldn't be trying at this point.
    It is a hot point NVLR333ET0WB, S/N HS223472H. This is the third time I've posted make and model, but I haven"t seen it post yet
    Thanks for trying. You may be right. As I said, the start switch hasn't even been set to start when this occurs, therefore the motor should not even be trying to start. My own suspicion is that it would possibly be the cycle selector. I will have to do a teardown to determine the issue at this point
    Thanks for the link
  • 4,323 Answers
Hi
Please unplug the dryer and check for any loose connections, burned contacts or loose power cord. If connection seems to be fine then try using the dryer with a different power socket. Hope this helps...please post back with make and model # for further assistance.
Daniel
Posted on Apr 09, 2011
  • Daniel Scott
    Daniel Scott Apr 09, 2011
    I believe it is the motor which has turned bad. You can check whether the electrical hum noise is coming from motor or the control panel. You can find the parts for your Hotpoint dryer from this link---
    Hope this help...
    Daniel
  • Daniel Scott
    Alright....post back for further assistance
Dryer will not turn on. Ive flipped the breaker and left it off for up to 5 minutes. Still no solution. THere is a humming sound coming from what sounds like the cycle knob. This is nothing new, it was...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 22, 2010 | Roper REX4634KQ Electric Dryer
When I push the knob for it to turn on the motor just hums, nothing turns on.
Yup... you have a bad motor... the humming is the motor trying to start and not starting...
You will need to replace the motor...
Check out this tip for further info on this problem...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Maytag SDE2606A Electric Dryer
Dryer makes humming noise
The motor has gone bad on your dryer...
Here is a tip I wrote about your problem....
heatman101
Mar 28, 2010 | LG DLE2512W Electric Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
When I turn the start knob on my Frigidaire Gallery Model GLER341A52 the motor makes a humming noise but nothing else, when I let the knob go it stops. The drum never turns or blower doesnt start it sounds...
Wow, different person, different dryer, same problem, same day. I went and got a complete new motor assembly for $170. I hooked it up, and it is still doing the same thing. So obviously that is not the answer. What did you find?
Nov 19, 2009 | Frigidaire GLER341A Electric Dryer
Maytag SDE4606AYW electric dryer won't start. After drying several loads successfully, I set the timer knob, there was a humming noise and the dryer won't start. The humming noise happens at any timer...
heatman101
dghj53
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
It won't start
Sounds like the motor start winding or motor relay is bad.. or something caught in you exhast blower. See if you can turn the drum with your hand.. if so you can try, helping it take off while having someone turn the start knob if it starts you know its the motor
Aug 19, 2007 | Frigidaire GLER642A Electric Dryer
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
21 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
