Question about Rule 1800 Gph Automatic Pool Cover Pump H53sp24 ()
New 1800gph pool pump - it cycles every 2 1/2 mimutes but dosnt stay on?
    President:
  • Rule Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Sorry to hear you are having trouble with the pump. Since it is new it is still covered by the 3 year factory warranty. You can try to contact the place you purchased it from or go straight to Rule..
Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
Or Rule direct at www.rule-industries.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 11, 2011
On leisurerite spa pool what does code 1-3 mean
If your system is equipped with a circ pump, it may be configured to work in one of three different ways: 1)
The circ pump operates continuously (24 hours) with the exception of turning off for 30 minutes at a time
when the water temperature reaches 3°F (1.5°C) above the set temperature (most likely to happen in very
hot climates). 2) The circ pump stays on continuously, regardless of water temperature. 3) The circ pump
will come on when the system is checking temperature (polling), during filter cycles, during freeze
conditions, or when the blower or another pump is on.
Dec 06, 2016 | Pool & Spa
Dish washer dosnt pomp the wather out and dosnt clean good
I would imagine your pump is either clogged or has gone bad. at any rate you need to remove pump and see if asny dirt debris is in the line. The pump being dirty or bad directly effects the cleanliness of you cycle as the dirty water can not be properly removed.
Dec 07, 2011 | Dishwashers
Pentair Legend with boster pump dosent stay on bottom of pool. Seems to float near top of pool more than it does staying on bottom when its suppose to be cleaning.
Make sure that your wheel RPM is not greater than 32. If the RPM is too high, the cleaner will be forced from the bottom of the pool. Make sure that your back up valve is cycling properly because it, too, can cause the cleaner to lose contact with the floor. You might need to use a diverter to make sure that the pool cleaners not getting too much pressure.
Feb 28, 2011 | Pentair White/Gray Legend Platinum...
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
New hayward 1 HP super pump runs 1 or 2 seconds, then shuts off. After 1 or 2 minutes, will come on for 1 or 2 seconds, then shuts off again
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
Jul 04, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
AQULINK CONTROLLER WILL NOT TURN OFF FILTER PUMP
Sounds like one of the relay's has gone bad inside the box. If your lucky you can move the wires to another relay if there is one available. Make sure you move the top wires too, not just the 4 bottom wires, or you will have to do some reprogramming.
Mar 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Sep 20, 2007 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Rule 1800 Gph Automatic Pool Cover Pump  H53sp24 () Logo
179 people viewed this question
Top Rule Pool & Spa Experts
Bill Jordan
Robco Water
Robco Water
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
