Question about Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive
My Dell PC scan says that my Samsung SP2504C hard drive is about to fail and should be replaced. Is this something I can do?
  • 1,591 Answers
Absolutely.
You're going to want to get some kind of drive imaging program like Acronis True Image or Norton Ghost (the only Norton program I do like) and make a duplicate copy of this drive to the new drive.
Procedure should go like:
install acronis true image
create bootable media
power system down
hook up new drive (do not disconnect old one yet)
boot the system from the acronis CD
clone the 250G to the new drive
power down and remove the 250G.
Your system should boot right up off the new drive (may do the new hardware found thing though)
NOW you should call 310-DELL and see if your 250G is under warranty - it just might be!
if it is, get it replaced, and install it in the system as a backup or data storage drive - or even sell it to help recoup the cost of the replacement drive. I suggest using it as a backup drive after this scare!
Why would we buy a new drive BEFORE checking the warranty you say? To save our OS and all our programs and pictures and music and whatever else is on the failing drive!
When you are buying the new drive, most shops will show you quickly what's involved in hooking up the new drive, since it only takes a couple minutes.
If you aren't comfortable with the whole procedure - go to a computer store and tell them you'd really like to buy a new hard disk and put the old one in another system, but you don't want to lose all your data. Most places will offer to do your transfer and installation for you - and since you said you wanted to put the old drive in another system, this ensures you get the original drive back!
Posted on Apr 09, 2011
Testimonial: "Cheers very helpful"
  • 41 Answers
Replacing the hard drive involves the following process:
  1. Turn off and unplug the computer
  2. Remove the two screws from the left panel (facing the front of the tower)
  3. Slide the left panel back and to the left to remove it
  4. Unplug both power and data from the hard drive
  5. Unscrew the hard drive (You may need also remove the right panel to get to additional screws)
  6. Slide hard drive out
  7. Slide in new hard drive.
  8. Screw in new hard drive in approximately the same fashion as previous hard drive was screwed in
  9. Plug in power and data
  10. Re-install panel
  11. Plug computer in and boot
However, if this is your main or only hard drive, you will need to install your Operating system and all of your software and files from scratch. It may be possible to preserve them, but that's often risky and requires a bit more work. If this is your main hard drive, you probably want to consult an expert on having the old drive contents moved to the new drive.
If you like my solution, please vote for me,
Testimonial: "Thanks"
Dell inspiron 6000 dst short test fail. ie freezes every so often
hi,
This means the drive is failing so please get ur data backed up and try to full format.
If does not work please change the HDD.
Thanks
May 28, 2009 | Dell Inspiron 6000 Notebook
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
PC Doctor error code Failed SMART Test Error Code HD521-2W
This is in an HP PC? This error (like most SMART errors) is indicative that your disk is on its way out. Your best bet is to buy a new disk quickly, and get important information off this one! SMART errors are usually fairly accurate, though occasionally disks go on for years.
(SMART = System Monitoring And Reporting Technology)
Jul 12, 2009 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Dell inspiron 1300 won't reboot. HELP!!!
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Apr 21, 2009 | Computers & Internet
Hard Drive
you will be able to connect this samsung hard drive which is a SERIAL ATA drive if you the SATA port on ***********-board(remove the jumper from the hard drive)...
after you are connected ,in your bios set the seagate as your primary booting device.....
after this is done you can continue the virus software
thankyou,.
regards
JC
Aug 13, 2008 | Computers & Internet
250GB harddisk only 130GB
try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Jan 16, 2008 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Hard drive
You may have to replace the hard drive. try this. with the computer turned off, hold down Fn key then press the power button. it will run a diagnostic for HDD. if it will fail starting with a error code 1000 something. replace the hard drive. call dell spareparts 800-3573355.
hope this helps. thanks.
Nov 24, 2007 | Dell Inspiron 1100 Notebook
Open Questions:
How To Fix Laptop That Won't Turn On 'Call +1888784-9316 In case you have encountered certain issues while working on your important project from office or while doing college assignments due the next day and now you are searching for some strong supportive tech support service, then get in touch with the tech support executives of Dataalign. Call Toshiba support for getting rid of all sorts of tech issues whether related to software or hardware. Getting tech issues fixed in a matter of few minutes is the speciality of tech support executives of Toshiba support. These executives of Toshiba are certified professionals and they make proper use of their expertise and years of working experience in the field of customer support for customizing a unique and exclusive tech support service according to the required need of the customer. We can say that Toshiba tech support is the simplest, effective and customer friendly tech service. It has got everything that makes a tech support service high in demand, like being pocket friendly, easy accessibility, available even at the odd hours, courteous and polite support executives. These technicians always try that all the customers they deal with, get satisfactory outcome and also experience friendly customer service. Toshiba laptops are famous around the world for their eye catching features and advanced technical characteristics that make them everyone's first choice. Still Toshiba customers face issues in their devices ranging from minor issues to major ones that can gradually lead to effecting the laptops performance permanently for a long term. Issues that are usually faced by customers are not able to process fast, getting the command keys wrong, screen freezing issue, blue screen of *****, frequent invasion of viruses, Trojans and malwares etc. Toshiba support has been helping customers to get rid of all these issues as soon as possible. Their assistance is available 24/7 through various modes of communication like via mail or through phone. They employ advanced techniques for resolution of issues and they use remote access process for their work which makes is more accurate and faster. Call on toll free helpline number +1 888 784-9316 anytime and get support anywhere. Enjoy the work being done in front of your eyes by asking for tech support service at the time and place of your choice.
Jul 17, 2018 | Toshiba Computers & Internet
See all Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Questions
Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive Logo
213 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
