Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
I have a haier dishwasher and it has stopped working,it's not filling water or doing anything
Check the small sensor along the rim of the door/door jam. It may be stuck. Free the machnism an start washing. Another common problem that cuase those symtoms is a bad door gasket.
Posted on Apr 09, 2011
  • Prem Mulberry Apr 13, 2011
    A good source for Haier dishwasher service manuals is here:http://steprightupmanuals.com/dishwasher...
2 Suggested Answers
SOURCE: Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
Posted on May 18, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Just hums won t start
Their is 2 screens towards the back right that are plugged up. . You can take out 2 screws out and clean them up. Or the fill level adjustment in the front left isn't working right. It also can be fixed with 2 screws and cleaned.
Apr 21, 2014 | Haier Dishwashers
I have a haier hdc1804tw it starts,pumps out old water, fills new water, than stops. It wont activate. Any advice?
Have you had any luck with this? Ours just started doing this tonight after no problems (had it for 3 years, light use). "Feels like" a pump isn't kicking in to pump the water to the arm.
Sep 14, 2013 | Haier HDC1804TW Dishwasher
Haier dishwasher did not pump out
I had problem like this...one day the washer stopped, still half-full of water. Then, we tried to run again and we could hear the little engine working but it wouldn't let water in OR out, just error beaps.
Then my boyfriend took off the back and gently tapped the water inlet valve solenoid with his screwdriver, and now it works! Starting FILLING actually, not draining, but completed a full cycle finally!
Must have shaken loose a blockage in the mechanics in that solenoid, probably have to replace before long. But for now, success!
Here is a website that helps: http://www.searspartsdirect.com/Haier/dishwasher/model-Esd301-repair/categories/dishwasher-repair/symptom/dish004.html
(See "REPLACE WATER INLET VALVE", half-way down page)
Aug 19, 2013 | Haier 17 in. HDT18PA Built-In Dishwasher
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
I close turn on and no water
if you can hear pump kick in then stop..... then you need to change valve inlet...
Feb 26, 2011 | Haier HDB24EA Built-in Dishwasher
My haier dishwasher is not filling with water just making a loud humming noise
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Nov 11, 2010 | Haier Dishwashers
Haier ESD200 won't stop running
i am with you on this...same problem...
May 14, 2010 | Haier ESD200 Built-in Dishwasher
May 16, 2009 | Haier Dishwashers
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
424 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Tom Chichester
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
