Question about Faberware FWM800P Deluxe Chrome Belgian Waffle Maker
When I plug it in, no lights come on. Kevin
  • 11,800 Answers
This is an extremely simple device: it's composed only from a power cord, a thermostat, 2 neon warning lights ans 2 power heating resistors.
If you don't get any lights when you plug it in it means that the power is not reaching the unit - open the bottom of the pan, at the hinge and check the power cord for continuity. If the cord is intact then the thermostat has failed. This means that the unit is dead - there are no spare parts available for it since it will be a lot cheaper to just buy a new one.
Posted on Apr 09, 2011
Car studders when accellorating, check engine light has come on
Hi Kevin, I'm glad to help!
Kevin there are a lot of things that can cause an engine to sputter and backfire. The first thing I would do is hook-up a fuel pressure gauge and tape it securely to the windshield so you can see the pressures while your driving. If the pressures drop dramatically during a heavy acceleration then you need a fuel pump. BUT, if the fuel pressures stay normal then its OK. The second thing I'd take a look at is the timing. See if the belt has jumped a tooth. OR if the chain has a lot of slack and cause a timing issue. I'm not sure what engine you have because its not in your question, BUT if you have plug wires make sure you didn't accidently swap two of the plug wires to the wrong cylinder. Hope this helps and have an awesome day Kevin.
Apr 01, 2013 | 2004 Ford Freestar
Car is hesitating and shaking when i come to a complete stop. what could that be?
Kevin, it could be a few different things. If your check engine light is on, get it scanned at Autozone. They might be able to pin point the problem. If no light, check all your fuses first. Check your air filter and your fuel filter. Check for vacuum leaks as well. If it has been a while since you changed spark plugs/coils, you may need to. I see you have a 07, so, anything more then or close to 70,000. I would recommend a tune up. You might have a bad dist.cap. Check the fuses first, then air filter and fuel filter. These are easy to check and they can cause stalling, as well as a vacuum leak. If they are good, you might need the tune up. It could be a bad plug. The shaking may be a bad front end. It may need to be aligned. It just depends on the miles you have and what you have changed over the years. Check your pcv valve also. I know it is a lot, but so many things can cause this. If you have a question, let me know. I am here to help. Kevin, thanks for using FixYa and have a good night sir.
Feb 23, 2011 | 2007 Lincoln MKZ
My H2O Man Mp3 player won't charge - light stays red (solid) when plugged into my computer. When I put it back together it won't turn on at all.
Hi Northernelf,
Please contact Intova directly at (808) 837-0074 or e-mail kevin@intova.net and we will gladly help to address the problem with your H2O Man MP3 player.
Thanks,
Intova
Feb 05, 2011 | H2O Audio Intova H2O Man MP3 Player
I have a kenmore ultra dishwasher 655.177779990 and the lock out light was flashing until I unplugged all connectors and plugged back in. Now light stays on and everything else has stopped working. Tried...
Hello & Welcome to FixYa
You are right, the unit needs a reset. To reset the control you can press and hold the AIR DRY/RINSE ONLY button for 15seconds to solve this issue. Please get back to me if you have any other questions.
Kevin
Dec 09, 2010 | Dishwashers
2003 Jetta
Hi Kevin,
I hope it stays fixed. If it does, I'd appreciate a rating when you have the time. Cheers, D.
Jul 20, 2008 | 2003 Volkswagen Jetta TDI
Trouble Code
Hi Kevin,
There probably isn't a single answer every time. I found this for you on my hard drive...
"18613/P2181/008577 - Performance Malfunction in Cooling System
Possible Solutions
* Check Engine Coolant Temperature Sender (G62)
* Check Coolant Thermostat
* Check Engine Cooling System
o Put the key on, fan speed on 1, and push the a/c switch. Are both fans kicking on? If not, you found the problem.
o Put the key on and fan speed on 1. Does heat come out readily from the vents?
+ No. Probably the water pump is gone.
+ Yes. Probably the thermostat is gone."
Check the electrical connector on the G62 first - make sure it is clean. Try running the engine with the G62 disconnected - does this make a difference?
Let me know how you get on. Cheers, D.
Jul 17, 2008 | 2003 Volkswagen Jetta TDI
My Book not being recognized
try downloading updated software from western digital, install then connect!
May 12, 2008 | Western Digital My Book Essential Edition...
Laptop won't turn on
Unplug the computer from the adapter and then take the battery out. Put the battery back in. Put the adapter back into the computer. Enjoy computer.
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Faberware FWM800P Deluxe Chrome Belgian Waffle Maker Logo
Top Faberware Kitchen Appliances - Others Experts
ashburton
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
