Question about Fossil Watches
Fossil wrist watch FS 4263. The small silver piece which indicates the 3rd. hour or 15 mins is loose. the watch was purchased on 24 12 2007. Where can it be repaired under warranty?
SOURCE: User Manual - Fossil CH2332 Wrist Watch
go to fossil.com click on customer support that is where the manuals are hope this helps
Posted on May 14, 2008
escapement
  • 2334 Answers
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Posted on Dec 19, 2008
escapement
  • 2334 Answers
SOURCE: Brand new watch won't work
Check your users manual if your watch have two batteries. If yes, you need to replace digital part battery.
If your watch has only one battery, your digital screen or plate is defective. Bring it back to the retailer and ask to replace for the decently working watch.
But first of all try to fiddle with all pushbattons- sometimes it helps.
Posted on Dec 20, 2008
escapement
  • 2334 Answers
SOURCE: removing links from watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 12, 2009
SOURCE: fossil authomatic wrist watch that does not
Thanks, I have been to a local expert for the advice
Posted on Oct 20, 2009
INSTRUCTION MANUAL FOR FOSSIL CH2698
See https://www.fossil.com/content/dam/fossil/PDF/watchinstructions/Fossil_Watch_Instructions_EN_US.pdf
The file is a compendium of instructions for a large number of Fossil movements, but it is unclertain which movements the model CH-2331 and CH-2698 watches use. However, movement OS10 (page 15) appears to be the only one that matches the dial layout, button layout and also has a date window as the CH-2331. The watch has a quartz analog mechanism and uses one SR927W 1.55-volt silver oxide button cell. Silver oxide cells have low current output, but very long shelf life, so if the stem is pulled out completely when the watch isn't being worn, the battery could last many years. Scan the instructions to match up the CH-2698 with a movement number. A good guess from examining photos of the face of a CH-2698 watch would be movements OS20 / FS00 or VD53.
Apr 07, 2014 | Fossil CH2331 Wrist Watch
What battery does the fossil fs 3105 watch take
It's actually a lot easier than that video shows. You're trying to represent a watch that is a PDA! To change the battery in your watch, you need to purchase a watch kit on eBay for about $15-$25, purchase the correct battery, watch a realistic video of changing a battery on Youtube, and then you will never need to pay more than the cost of a battery (a few dollars) to change your watch battery ever again! Sending it to Fossil takes time and money and you can do it at home with basic skills!
Jan 16, 2011 | Fossil FS3105 Wrist Watch
I have a Fossil Arkitekt wristwatch (FS-2919). on of the hands on one of the three tiny dials has come loose and is floating around the face. I probably wouldn't care, but the main watch hands get caught...
You will have to remove the back off the watch (cant take off the face). You MIGHT be able to access the hand from there, but you may have to adjust some of the watch inner movement and that will be risky but you can try.
Goood luck
Aug 21, 2010 | Fossil FS2919 Wrist Watch
Battery
mcdevito75 here, It may be a 364 or a 377 It"s not so easy, many styles of Fossil watch out there.
Jul 14, 2010 | Fossil FS3042 Wrist Watch
I have a Fossil automatic wrist watch FS-4196. Is there an easier way to set the date than to run the hands around until you get to the correct date?
Pull the crown all the way out, it will advance the day by one. it will spring back to the hour adjust position, so you just repeatedly pull the crown out until the desired date is achieved.
Jun 11, 2010 | Watches
2 months after it was purchased I placed it on its side and it quit working. The story that sold it to me will not take it back. This is the 3rd time this paticular model watch has quit working for me.
It should still be under warranty.
Go to Fossil.com and send it to your nearest service center (with proof of purchase).
They should fix it for you.
Mar 07, 2010 | Fossil AM3784 Wrist Watch
Fossil fs-4167. the small fake diamond in it is stuck on sec hand
You have to open your watch, take out stem completely, then take out whole movement and release the stone. I you have steady hands, nimble fingers and a pair of tweezers, you will be able to refit the stone using Superglue.
Jan 12, 2010 | Fossil FS2920 Wrist Watch
Adding Links to Watch
call fossil - you can order them and they come within 5-7 business days.
Nov 16, 2006 | Fossil FS3029 Wrist Watch
Watches Logo
119 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
