Question about Jandy Lite 2 Natural Gas Pilot Light Heater
I have a Jandy Lite 2. I just opened my pool and wanted to heat it. The burner flame is surging. Could my regulator valve need replacing? Thanks!
    Top Expert:
  • Jandy Master
  • 5,779 Answers
Could be check gas pressure also see if your gas meter is big enough
Posted on Jan 30, 2016
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 22 Answers
SOURCE: Jandy lite 2 LG pool heater
ignition control board failure
Posted on Feb 18, 2009
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
  • 990 Answers
SOURCE: I have a Jandy Lite
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Carrier Weathermaker 8000 Furnace Flame Surges on start up
The fuel is controlled by the gas valve, the amount of gas is controlled by the regulator, I would verify that the inlet gas pressure is within the limits of the gas valve/regulator. The surging is likely the fault of the regulator and could be as simple as a spec of something in the orifice that allows gas pressure on the top of the gas regulator diaphragm. With the surge there must be an accompanied change in gas pressure at the gas valve outlet to the burners, use a "U" bend manometer to verify as they are the most simple and accurate and react instantly with no "averaging" software to wonder about.
Mar 16, 2017 | Carrier Heating & Cooling
What is the flame sensor
The flame sensor is attached to the pilot light. It's down on the right side of the burner tray and usually has an orange wire attached.
The flame sensor lets the heater know that the pilot light has been lit and it's okay to open the main valve.
images?q=tbn:and9gcs_-csiy0xlxc4vgn5fxb5i4km7zxxkzfpham9qknrvchqj1v19hq
Mar 06, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
I ran my Jandy Lite 2 pool heater for 6 hours yesterday and the pool temp did not alter. The burners are working but the water is still cold. I have a seperate line that runs off just after the header...
Thank you for posting your question here on Fixya.com.
There are only two things that can cause a heater to run yet doesn't adequately heat the water. One is a clogged up and sooted over heat exchanger. It seems odd you do not mention periodic cycling of the heater too as usually you get heat roll-out from the bottom of the heater when this condition is present and that will trip a heat sensor from time to time.
Opening the top of the heater to expose the heat exchanger tubing will confirm this. If it is all tarred over it needs to be removed and steam cleaned and/or power washed to remove all the soot; once cleaned the heat can then be transferred thru the exchanger into the water.
The other possibility is poor gas flow either due to poor gas pressure or clogged up orifices, manifold or burner tubes. With the heater running inspect the flames from below. If they are bright blue and 2 - 4 inches tall on all the burners you heater is running fine. If not, you need to resolve the gas flow issue.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
May 29, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Heats to only 300 degrees? i have replaced everything, sugestions?
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 29, 2010 | Jenn-Air Grilling
Flame not staying lit
Ben Gaetani
Tanks 2 You Propane
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
When I light my grill only one side of the burner has a flame, on all 3 burners. I cleaned everything and even cleaned each hole in the burners. What's next?
Ben Gaetani
Tanks 2 You Propane
Mar 02, 2010 | Grilling
One burner barely lights; others don't light at all.
This is a common problem with grills purchased after 2001 or with a full propane tank with a lot of pressure in it. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
Ben Gaetani
Tanks 2 You Propane
Feb 23, 2010 | Weber Genesis Silver B Grill
Is not heating properly , the flame is not as strong as it used to be.
Ben Gaetani
Tanks 2 You Propane
Jan 18, 2010 | DCS BGB36BQARN (NG) Stainless All-in-One...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
