Question about Maytag Ovens
My Maytag Advanced Cooking System Oven'a Broiler isn't working when turned on. There is no smell of gas it just doesn't heat up.
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: My kenmore gas oven won't heat. I turn to dial to
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Posted on Oct 22, 2009
SOURCE: Maytag advanced cooking system/the super capacity plus
My Maytag , advanced Cooking system , super capacity gas stove has a problem with the oven. It looks like it lights, but most often, doesn't heat up, and I can sometimes smell gas. Anyone know what what cause this?
Posted on Jul 13, 2010
How do I fix my Maytag Performa oven displaying an F3 code?
Free Online Oven Repair Manuals
Appears the the oven temperature sensor is bad and needs to be replaced.
Aug 03, 2014 | Maytag Ovens
Oven wont turn on when stovetop does. It's a maytag advanced cooking system. Any advice appreciated.
I seriously suggest to you to call the gas company an have them send a man out to do a thorough check on that. Do not play with natural gas. Please have them check it. They will determine very quickly what it might be. There is a very good chance it might be a faulty pilot light especially if you have the electronic type an I am sure you do. Do you get any kind of gas smell when you turn it on?? If not then something wrong with gas imput for the oven. Pat
Dec 29, 2012 | Ovens
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Jul 20, 2011 | Ovens
The broiler does not turn on in my Maytag free standing oven. The ignition light glows but no flame comes on. You can not smell any gas. Any suggestions?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 16, 2011 | Maytag Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Maytag Ovens
MY BROIL ELEMENT WON'T IGNITE ON MY MGS5870ADW MATAG GAS RANGE AND I DON'T KNOW WHAT PART TO ORDER. BACK ELEMENT OR IGNITER IS GLOWING RED.
It could be that the ignitor is weak and only partially heating which could be causing the gas control valve not to open and allowing the gas to flow into the broiler burner tube.
I would also suggest you see if you can smell gas to confirm that the gas supply valve is actually opening up. With the oven door closed, turn on the broiler and after 20-30 seconds of having the ignitor glowing red, turn off the broiler control and open the door and see if you can smell gas, if not it could be either a weak ignitor or a faulty gas control valve.
I would suggest that before you start ordering parts, you swap out the oven ignitor with the broiler ignitor to verify that the broiler ignitor is the problem. It could also be the broiler tube has a blockage of some sort possibly from cooking debris, that is preventing gas from flowing into the tube.
Here's a diagram for your unit along with the parts list.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGS5870ADW&productCategoryId=0124250&brandId=3048&modelName=MAYTAG-COOKING&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=M0412019&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this very helpful and best regards!
Aug 07, 2009 | Ovens
Jan 20, 2009 | Maytag Ovens
Won't heat up
You have two ignitors one for bake and one for broil your bake is not working
Nov 09, 2008 | Maytag CWG3100A Gas Single Oven
Oven is locked
press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
Ovens Logo
105 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
