Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
I have a kenmore gas grill that has the side burner. Up until recently, it has been working great. However, now the main grill won't light when pressing the ignition button but the side burner lights instead (something we rarely use!!). We can manually light the grill but it is only 1 1/2 years old - help! Thank you! DMac
    Brigadier General:
  • 4,736 Answers
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Posted on Apr 09, 2011
The grill burners are not lighting, but the side burner does light. I have a 3 year old Kenmore grill with four burners.
Brian, is it case of the 3 ignitors not working or is it a case of gas not getting to those 3 burners? Have you tried match lighting any of those 3 burners?
I ask the above questions in an effort to determine which solution will work for you. Please advise and thanks for choosing FixYa.
Aug 02, 2011 | Kenmore Grilling
Just purchased new Brinkman 5 burner Pro series. Worked fine when I tested it but now the main burner is the only one that will ignite and it won't stay on. The side burner works great.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kinks or twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
Hope this helped you . Please let me know and Happy Grilling.
Jun 19, 2011 | Brinkmann ProSeries 810-6330-W Grill
Just came home with a new tank of gas, was working great before that, now the main grill will not light,however, the side grill lights.
In a round-about way, the problem is with the new tank of gas. Here's what you need to do to correct the problem.
Turn the gas tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the main burner of the grill, that's farthest from the tank and turn it to HIGH, Has the flame height on that burner returned to normal? If so, light the remaining main burners the same way. Do all the flame heights, now look normal? If so, you solve the problem. Just remember to always turn the tank valve on very, very slowly.
Hope this helped you solve the problem and Happy Grilling!!
May 20, 2011 | Brinkmann 810-2300-B Grill
I have a stainless steel Kenmore propane grill, model 119.16311800. It has four burners and a side burner on the left. It is two years old and has performed perfectly for two years. I am now having...
With all the you described, your best bet is to replace the grill hose/regulator assembly. It's not expensive and it's not difficult to do. You can find the hose/regulator assembly at any home center or hardware store that sells gas grills. The assembly is universal, but take your old one with you for comparison purposes.
As far as replacing the burners are concerned, that's not difficult either. And you may be able to find the replacement burners at www.sureheat.com , as they made the Kenmore grills for Sears. And yes, the scenario you gave for removing the burners is correct.
Hope this helped you and you will be kind enough to give my response to you, a positive rating.
Happy Grilling!
Mar 26, 2011 | Kenmore Grilling
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Replace main burner bracket - Kenmore 141.17227 nat gas grill
I've been screeming at my employeer about this design for years!!! I know what you are trying to do- I have to work on them,even in 90 degree weather!!!! Find the screws that hold that side panel on,remove screws, have someone else there to help you hold it in place- best to get the HARDWARE pack also, its new screws as the old ones will be rusted in, I've even had to grind some of the old screws to get them removed.. Good luck , at least you know someone else is having same problem...
Sep 05, 2009 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
324 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
