Question about Dell (58GGC) Motherboard
My Dell Computer Processor fan runs too fast continusly, it wont slow down, pls help me.
  • 41 Answers
Your processor fan is designed to run in response to the temperature sensor thats on the motherboard. If it's running too fast, it's likely your processor is running too hot. Make sure the case has adequate ventilation and is clear of dust and debris.
If you like my solution, please vote for me,
Posted on Apr 09, 2011
I need only circuit schematic diagram
Restart it or get off of gamesites or things like, Minecraft, Call of Duty, Terraria, and others like those. If a game takes a little to load and after a while you can hear the fan getting louder you can do something else until the fan starts to slow down a bit.
Dec 25, 2013 | Dell OptiPlex GX280 PC Desktop
My gx620 thermal fan overheats
A) FOLLOWING Anti-Static Procedures;
1) Clean the inside of the computer out
2) Replace the Thermal Paste on the Processor (CPU)
THOROUGHLY clean top of CPU (Processor), and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx620
Click on the blue ->
Dell Optiplex GX620 System User's Guide (5990KB)
Using Mini Tower Computer as an example;
In the list click on;
1) Removing the Computer Cover
2) Processor
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
Dell vostro 270 slow
What is the question here? I have this same PC and it is fine. How much RAM do you have? Was it always slow or has it slowed down over time? Have you run a scan to check for virus? More info is need.........
Jan 13, 2013 | Dell, Inc Dell Vostro 270 Desktop...
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Dell E6400 Monitor Flickers and laptops heats up fast.
The overheating is caused by:
  1. Clogged heat exchanger
  2. Slow or failing fan
  3. Poor contact with heatsink and processor
If under warranty, contact tech support for repairs (800)624-9896 USA
If not under warranty, try clearing the heatsink via canned compressed air, you should be able to access it easily after removing the bottom cover. If no help. try arctic silver heat transfer compound between the heatsink and the processor. If the fan fails diagnostics, replace the fan (easy to get on ebay)
For the flicker, try reseating the video cable to the motherboard
Jun 12, 2011 | Dell Latitude E6400 Laptop Computer PC...
Hi, how to switch off HP Proliant DL320 G2 server fans? In Normal fans speed and noise
The fans are essential to the cooling of the processors and everything else in there, if they are running fast then usually that means your processor is overworked. I'd go for a fresh operating system if you can.
The fans should come on really fast when its first turned on, then slow down after a few minutes.
Oct 29, 2010 | HP ProLiant DL320 G2 Server
My computers cooling fan keeps speeding up and slowing down is that a good thing or a bad thing
I'm assuming your desktop has an AMD processor?
AMD have a process called "quiet and cool" this basically speeds up the fan when the processor is under load and getting hot or slows it down when the processor isn't working as hard.
Regards
Mike
May 26, 2010 | Dell Inspiron 531s Desktop Computer
I have Dell GX280 system. My Fan produces more sounds and runs fast. System Hangs while processing and performs slow, causes processor nore hot. I pasted the Heat Sink Paste on processor that resuls in low...
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Sep 09, 2009 | Dell OptiPlex GX280 PC Desktop
Assalaam-o-Alekum and Hello This is Bilal, I have Dell optiplex GX280 with 3.2Gh processor. Iam facing a problem with a cooling fan which install for cooling of processor. Thats run very fast after few...
Hi, I have the same computer, and the stock fan that's installed has a very high rpm. It is a variable fan that can actually be set in the bios to run in a quiet mode or in a mode that is more for heavy work, like your gaming, or other intensive work that requires a lot of processing. Other tasks that require the processor to work harder are graphics, CAD, audio recording, and video editing and viewing. You will notice on your dell, that you can actually hear the fan go through different speeds depending on how much work the processor is doing. It can get loud, and you may even think that maybe something is wrong with your fan, but that's just the fan attempting to cool the processor as it's working. This is software controlled based on the temperature reading of the processor chip. To use a quieter mode, you can enter your bios during startup, and find the fan settings. Change the fan setting to the quieter mode (it actually reads something like "quiet mode" or office mode" or something like that - very easy to determine. Then save your settings and exit bios. I need to tell you though, it's not much quieter. There are quieter fans you could buy for your CPU, but it may not be worth it to you. I had my cpu sitting on top of a side desk, and it was unreasonably loud. I plaecd it on the floor under the desk, and now I can barely hear it. Maybe you need to place your cpu further away from you in such a way. You can even get foam and "soundproof" your cpu, remembering of course, not to cover the ventilation holes in your case, or cover any part of the processor or motherboard - just the interior walls of the case. A lot of techs I know who need their processor near them (disk and rear panel access) use this technique. Hope this helps.
Jun 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
Fan
No reply
Can't help without details, sorry
Apr 16, 2008 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
Dell (58GGC) Motherboard Logo
131 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
