Question about ViewSonic VA1912wb 19" LCD Monitor
My viewsonic Va1912wb flashes horizontal lines when you turn it on and i know it is not in pal and it is not the refresh trate help me please
  • 384 Answers
Hi There and Welcome to Fixya.
Horizontal or vertical lines flashing/running across the screen poses serious display issues with any LCD/CRT monitors. It only boils down to 2 possible causes :
  • Corrupted video driver
  • Hardware issue
To help you determine which of the above, here's what you need to do.
  • Ensure that the computer is turned OFF
  • Disconnect ALL USB devices except the keyboard
  • Turn the computer on and immediately hit "DEL" (in some systems, it's the "F2") key repeatedly until you reach a different screen. (not the usual Windows screen)
  • Welcome to the BIOS screen
  • From here, spend 30min to 1 hour observing if the lines are present in this mode
If you still see the horizontal lines, then there's a need for the monitor to be serviced by a certified/trained technician. The link below will direct you to their support page for repair/replacement options, depending on your warranty status :
ViewSonic Support
Otherwise, the problem can be resolved by re-installing the operating system.
I hope this helps, Thanks for using Fixya.
Posted on Apr 09, 2011
Hi, my Viewsonic VA1912wb monitor fails to wakeup after being turned-off over-night without many cyles of switching on andoff. The screen appears briefly, but then goes black with horizontal static lines....
More likely to have bad DC filter caps with leaking/bulging tops just like the failed VIEWSONIC as shown in my albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic - it has horizontal line flash.. How to fix?
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
http://stores.ebay.com/LCDALTERNATIVES
Good Luck!
May 12, 2010 | ViewSonic OptiQuest Monitor
Monitor fails during boot
the problem is due to hi-esolution, boot in SAFE MODE uninstall / reinstall the video drivers
Feb 07, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
Wide, snowy horizontal bars scrolling on Viewsonic VA1912WB
Changing computers doesn't help. Followed all suggestions from Viewsonic Tech Support. Problem is in monitor circuits--had to replace it.
Dec 23, 2009 | Acer AL1916W 19" LCD Monitor
No sound
Have you connected the supplied lead(s) from your monitor to your sound card?
If this helped please vote
Oct 09, 2009 | ViewSonic VA1912wb Monitor
No display on Viewsonic VA1912wb
Your monitor sounds like it has gone bad. Cost for a repair is not worth it, a new one would be cheaper. Prices have gone down a lot in three years
Sep 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA1912wb 19" LCD need sound driver
operation174 -
Here is the driver download page for your monitor:
http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1912wb
Choose the correct download for your operating system.
Thanks,
videoman7
Aug 07, 2009 | ViewSonic VA1912wb 19" LCD Monitor
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
Jul 09, 2009 | ViewSonic VA1912wb 19" LCD Monitor
A line of Dead Pixels.
You are right it is a stuck or dead pixel, usually if it is a colred line but not grey it is a stuck pixel at the beginning of the line you can try a utility designed to flash bright colors repetedly over time to see if this will "unstick" it. Also you could have a dry joint on your TCP which would require opening it up to diagnose.
Feb 11, 2008 | ViewSonic VA1912wb Monitor
ViewSonic VA1912wb 19" LCD Monitor Logo
270 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
