Question about Car Audio & Video
Radio not turning on but fuse is good on the panel
    Sergeant:
    Champion:
  • 207 Answers
Have u tryed the fuse on the back of the radio.
Posted on Apr 09, 2011
How to find my fuse box and check if me fuse for the radio is bad
radio fuse is on left side under the dash . remove the side panel and find the fuse for radio
good luck
Apr 03, 2015 | 2003 Toyota Corolla
How do I get the radio to turn off????
my guess is someone has installed an aftermarket radio?
your yellow and red wires are backwards on the back of the stereo. you've got constant 12v power going to the ignition/memory wire on the stereo.
Oct 11, 2014 | 1996 Ford Explorer
Gauges,Radio,wipers and headlight won't work.
Sounds like you have at least one blown fuse. Check the fuse panel, It's on the driver's kick panel next to the dead pedal (where you rest your left foot) to the left. of the clutch. The cover for the fuse panel faces the center of the car.
Here is a picture of a good and blown fuse:
Jan 09, 2013 | 1988 Nissan 300ZX
Clock and radio will not stay as set on my 2010 terrain when i turn the car off.
Hi!!Check on your owners manual for the location of the radio fuses, there should be two, one that is hot at all times which keeps the clock and radio set (which may be the one blown) and the other one for the ignition switch. They should be on the under dash fuse panel.
Good luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 16, 2011 | 2011 GMC Terrain
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
Radio stopped working radio will turn clock on and then go out in 5 seconds tried two used radios and same thing fuses good no corrosion under fuse panel
your harness needs inspection-getta a repair manual for vehicle model it has wiring diagrams--wiggle test may be useful
Aug 18, 2010 | Dodge Caravan Cars & Trucks
Radio has no sound, not the fuse as the lights are lighting up on radio or cd but no noise what so ever...just quit??? Went to turn car off and thought I hit some type of mute button by mistake...I have no...
Make sure and check both fuses.There are usually 2 for the radio.One for clock and lighting and one for power.There is a fuse panel on the passengers side also.So there is one fuse panel on the left side of the instrument panel and one on the right.One fuse is in the left and the power fuse is on the right side panel.Hope this helps.Good luck.
Jan 21, 2010 | 2003 Oldsmobile Alero
Fuse Panel - (for radio fuse) 89' Buick Lesabre
There are usually encased fuse boxes under the hood look for that. good luck
Jan 03, 2010 | 1989 Buick LeSabre
Chevy impala 06 radio just qont turn on
Probably radio if fuses are not blown,see owners manual for fuse locations.should be 2,those model gm radios are natorious for internal failure. If radio is problem do keywork search for LKQ or Greenleaf,both supply low mileage parts including radios with good warranty,will ship anywhere.Insurance companies use them.
Jun 18, 2009 | 2006 Chevrolet Impala
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
